norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2? I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the st...
chirpa
May 07, 2014Luminary
There is a serial port on it, would need to get a cable to connect to it. There are forum posts on the subject for wiring and such.
You could install /boot onto the internal flash, and /, etc on the disks. That should let you boot GRUB/etc from the flash through the BIOS and get into your OS. You would be wiping the flash, just DD a copy of it for backup if you need to restore it one day (its only like 6 files on FAT partition).
