norbolt
Mar 27, 2013Aspirant
Debian Squeeze/Wheezy on Ultra 2?
Is there a way to get rid of all the netgear stuff and just install vanilla Debian on the Ultra 2? I connected a serial adapter and I'm able to fiddle with the BIOS and select a USB stick as the st...
dkager
May 07, 2014Aspirant
chirpa,
Thanks for the info! Is the serial connection purely text-based? I'm afraid my eye-sight is too limited to use something like the VGA out found on the bigger NAS systems (which is also one reason why I installed through SSH). I can do plain text, not text that's rendered and then sent over.
I'm currently doing exactly what you suggested: have Syslinux on the 128MB vfat drive and the rest on the hard drives. My motivation for switching to /boot on my primary partition is mostly cosmetic: I want to wrestle all the USB1.1/USB2.0 modules out of my running kernel. The USB1.1 ports are internal, the USB2.0 ports are on the back of the unit. I'm not very likely to ever use either.
I kept Netgear's partitions around, that being a 4GB rootfs, 512MB swap and ~2.7TB data. My two disks are in RAID1, which probably complicates my chain booting. All partitions minus swap are ext4, no LVM or other tricks. I could write a script to mount the internal flash drive only when updating the kernel, something like this (except not for EFI but for the internal flash):
https://wiki.archlinux.org/index.php/EFISTUB#Using_systemd
But that would not be as "clean" as booting directly from /boot on the rootfs. When Googling I ran into someone flaming about CHAIN BOOTING A SECOND SYSLINUX ON A SOFTWARE RAID1 IS UTTERLY IMPOSSIBLE OH NO, but I haven't managed to find a definite "yes" or "no" to this question.
Apart from this one thing the system is running very well, has been for over a week. And I get Samba version 4, much like RAIDiator 6.x! ;)
