Darkyputz
Sep 05, 2019Aspirant
Deleting snapshots that are not showing
Hello Community... I was a silent reader so far and learned and got a lot out of here so far. But now i have a problem that i cannot resolve with the answers i found so far. About my issue: I hav...
Sep 05, 2019Guru - Experienced User
When did you convert to OS-6? Do you recall what firmware was running back then?
Have you ever tried doing a balance?
- DarkyputzSep 05, 2019Aspirant
Hello...
Thx for answering...
The firmware was the latest 4.2.31 one.
I did balance and scrubbing and the command i was reporting earlier...
Tried to navigate through the nas with winscp to find hidden /.snapshot folders in my shares but so far no luck
is there a linux command for searching those snapsot folders?
- StephenBSep 05, 2019Guru - Experienced User
Darkyputz wrote:The firmware was the latest 4.2.31 one.
Sorry - I meant the first OS 6 firmware version you installed.
Yes.
# btrfs subvolume list -s /data
will show you all the snapshots in the data volume. If you are using FlexRaid, you'll need to replace /data with the volume name(s) you configured when you created the volume(s).
Hello...and thx for the quick reply again...
I did the command you posted and it showed a good amunt of snapshot folders that i am not able to see in winscp
Prob my lack of BTRFS knowledge pays into that
How could i easiest get rid of them now?
is there a proven wildcard rm command or do i have to delete one by one?
Please advise
