Darkyputz
Sep 05, 2019Aspirant
Deleting snapshots that are not showing
Hello Community... I was a silent reader so far and learned and got a lot out of here so far. But now i have a problem that i cannot resolve with the answers i found so far. About my issue: I hav...
Sep 05, 2019Guru - Experienced User
When did you convert to OS-6? Do you recall what firmware was running back then?
Have you ever tried doing a balance?
Darkyputz
Hello...
Thx for answering...
The firmware was the latest 4.2.31 one.
I did balance and scrubbing and the command i was reporting earlier...
Tried to navigate through the nas with winscp to find hidden /.snapshot folders in my shares but so far no luck
is there a linux command for searching those snapsot folders?
- StephenBSep 05, 2019Guru - Experienced User
Darkyputz wrote:The firmware was the latest 4.2.31 one.
Sorry - I meant the first OS 6 firmware version you installed.
Yes.
# btrfs subvolume list -s /data
will show you all the snapshots in the data volume. If you are using FlexRaid, you'll need to replace /data with the volume name(s) you configured when you created the volume(s).
- DarkyputzSep 05, 2019Aspirant
Hello...and thx for the quick reply again...
I did the command you posted and it showed a good amunt of snapshot folders that i am not able to see in winscp
Prob my lack of BTRFS knowledge pays into that
How could i easiest get rid of them now?
is there a proven wildcard rm command or do i have to delete one by one?
Please advise
You can't use rm at all. These are BTRFS subvolumes, and not ordinary folders. rm will simply fail.
You can remove them one at a time with
# btrfs subvolume delete -c /path
using the full pathname of each subvolume in the list instead of /path. The -c option stands for "commit-after". The command won't return until the subvolume is fully removed. It will go faster if you leave out the -c, but I suggest using it anyway.
Make sure you are logging in as root (NOT admin). Use the admin password though.
You could probably sort out a way to script this, but I won't attempt to do that here.
