Newsat11
Apr 28, 2016Luminary
DNS options for ReadyNAS?
I'm looking for some advice regarding setting up a DNS for my ReadyNAS. There is a very nice article on setting up a general website at http://kb.netgear.com/app/answers/detail/a_id/24829/~/readynas-...
Apr 29, 2016Guru - Experienced User
If you are using ordinary DNS, you'll need to get a static public IP address from your ISP (so your router's external address is always the same). Then you need to create a DNS record that uses that address, and (as JennC says) forward the relevant port in your browser.
It's cheaper to use DDNS, but I don't think you can use your existing domain name if you go that route.
Newsat11
Apr 30, 2016Luminary
I'm not using a DNS at all, I simply purchased the domain name. There seem to be some third party applications for DNS available for ReadyNAS and I was inquiring about the simplicity and setup. I would like to use my ReadyNAS for all of my services. I am aware of the need for a static IP, but the domain name still needs to be associated with IP address through a service. I was just wondering if the DNS applications that are available work well for this? Do they also have mail exchange built into them? I was looking for someone who had used them for this purpose before, as I hate being a guineapig.
- StephenBApr 30, 2016Guru - Experienced User
Generally the registrar you used to get the domain name takes care of DNS as part of the service. So start with them.
I don't think there are any apps on the NAS that will help with this.
- Newsat11May 01, 2016Luminary
I had a feeling you would say that, and I am checking with them now. I wondered would they take care of registering my static ip, but I haven't really been able to get a straight answer from them,as they only seem to want to sell me hosting services. Not a surprise. I am just trying to make sure I don't make a mistake this close to finishing my project.
There are third party applications for DNS from Poussin and ReadyNAS Guru. A mail server is available from the iredmail app. I'm going to find out what service comes with my domain name registration, but I am pretty sure I will need both a DNS and email exchange app to upgrade my ReadyNAS to match the services I would get from a hosting service. I might add the webdav for calendars and contact to round out everything I need, but I am pretty sure GoDaddy only offers these services if you pay for hosting.
- StephenBMay 01, 2016Guru - Experienced User
The two apps appear to be front-ends for BIND. It might be possible to use them for what you want (though its not something I've done myself). There are some guides - for instance: https://www.howtoforge.com/how-to-run-your-own-dns-servers-primary-and-secondary-with-ispconfig-3-debian-squeeze
