jasonhollett
Jul 16, 2008Guide
Enabling .htaccess
Hi, I've been trying to get .htaccess files working on my ReadyNAS, but Apache doesn't seem to be setup to do this by default. A .htaccess file on my server with just "RewriteEngine on" causes a 40...
dbott67
Jul 29, 2008Guide
tcblack wrote: Now I'm buffaloed. The shares.conf file is NOT staying edited. Whenever I reboot it reverts back to Options Indexes.
I'm using firmware beta t120
I seem to recall this being an issue with a number of system files that were overwritten during reboots. You can use the following command to make the file immutable:
chattr +i /path/to/file
To unset the file:
chattr -i /path/to/file
If you search the forums for 'chattr', you'll find threads related to your issue, but some of them are still out in the ether thanks to the server crash.
-Dave
