user09ger
Feb 21, 2012Follower
Error with apt-get install iperf - please help
Hi,
my home-network is very slow at the moment and I have to troubleshoot. My problem: I am aprrox. 500 km away from home and have only ssh. So I tried this:
But I got that result:
My squeezeboxserver is running fine after a long periode of trouble and I don't want to change anything at the moment. Is there a way to bypass this squeezeboxserver-dependency-thing? I only want (need) to install iperf.
What I also tried was this:
I downloaded the deb-packet from the Debian-site manually and tried to install it with dpkg:
Any help is greatly appreciated. Thanks in advance.
Reading Package Lists... Done
Building Dependency Tree... Done
iperf is already the newest version.
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
iperf: Depends: libc6 (>= 2.7-1) but 2.3.2.ds1-22sarge6.infrant1 is to be installed
Depends: libgcc1 (>= 1:4.2.1-4) but 1:3.4.3-13 is to be installed
Depends: libstdc++6 (>= 4.1.1-21) but it is not going to be installed
squeezeboxserver: Depends: sox but it is not going to be installed
Depends: libvorbisenc2 but it is not going to be installed
Depends: libvorbisfile3 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
dpkg -i iperf_2.0.4-1_sparc.deb
Selecting previously deselected package iperf.
(Reading database ... 13044 files and directories currently installed.)
Unpacking iperf (from iperf_2.0.4-1_sparc.deb) ...
dpkg: dependency problems prevent configuration of iperf:
iperf depends on libc6 (>= 2.7-1); however:
Version of libc6 on system is 2.3.2.ds1-22sarge6.infrant1.
iperf depends on libgcc1 (>= 1:4.2.1-4); however:
Version of libgcc1 on system is 1:3.4.3-13.
iperf depends on libstdc++6 (>= 4.1.1-21); however:
Package libstdc++6 is not installed.
dpkg: error processing iperf (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
iperf
1 Reply
- WhoCares_MentorMost likely you just downloaded the wrong package. Try downloading from archive.debian.org, not the official current repository.
-Stefan
