davidmarli
Feb 21, 2025Aspirant
R8000 - impossible to install
Hi,
I just pick up an old R8000 (certainly with old firmware (I installed it a few years ago, perhaps 6 years, in my office)
I reset it, and wanted to setup it up at home.
I want to use it as a wifi + eth switch and not as router.
So I reset the R8000 (pressing the reset button for a few seconds).
The initial wifi network appears after a few minutes of booting.
With my laptop I connect on the netgear wifi.
Then I open up a browser and a page for configuring the R8000 appears.
BUT, once I choose to use it as acces point, I can change the ssid and password of the wifi, it reboots, and then impossible to login to the R8000
If I check the ip adresse of the R8000 (192.168.1.123) and try to connect to it : it says error 404, server error.
So impossible to get access to the Router to do an update or configure anything.
the routerlogin.net adress goes nowhere.
I try with nighthawk app on my phone, but the router can not be found !!!
So If someone can take a few moment to explain me how to do it ?
Thank you very much for your help.
Hi,
thankl you very much for all your answers.
I managed to do a reset and managed to update the firmware.
The way it worked : just wiring an ethernet cable between 1 of the 4 eth port and my laptop.
I accessed the router with 192.168.1.1
Now I can configure it.
Once again thank you very much for all your help.
Be sure to use the WAN port to connect the router to the host routers LAN port.
Try setting a static IP address configuration on the R series router instead of Dynamic. Try setting it to 192.168.1.80.
Is the host routers IP address sub net pool 192.168.1.x?
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985- davidmarliAspirantHow do I log to r8000 ?
I can t...
When I try using it s ip adresse (192.168.1.123) it tells me files are missing....
Nighthawk app doesn t work...- FURRYe38Guru - Experienced User
Try a factory reset on the router and then walk thru the setup wizard.
Then follow the PDF to setup AP mode for the .80 IP address, after you apply that, you should be able to log into the AP mode configuration at 192.168.1.80.What FW version is on the router?
