rengler
Apr 03, 2018Tutor
Excessive bandwidth using S3 backup feature
I have a ReadyNAS 316 (6.9.3) and have been using the built-in S3 backup utility for three of the shares on the NAS. These shares total 3TB of data, and all of that data is being successfully replica...
OOM-9
Apr 04, 2018NETGEAR Expert
The tool is configured to run like a syncing service and runs a check every 30 seconds. There were some checks that we are running to make sure that we only backup the difference. Those checks should not take so much bandwidth as you were mentioning.
We would like to take a look at your unit to see if there are any anomalies in your S3 sync. Can you enable Secure Diagnostics Mode and send me a message of the 5-digit number?
