super_poussin
Sep 28, 2008Virtuoso
eXtplorer for the PRO
eXtplorer
- Description: Powerfull php file manager with integrated ftp client.
- Requirements: RAIDiator 4.2.1+ and PHP Addon for the PRO
- Platform: x86
- Current Version: 1.2
eXtplorer (02/22/09)- updated to eXtplorer 2.0.1
- should support webdav but no how-to enable it :(
- Can now be disabled
- Copy & Move Files and Directories by Drag&Drop
- Dynamic Directory Tree with on-demand loading of subdirectories
- Edit Files (with Syntax-Highlighting thanks to EditArea)
- Rename, Delete or Create new Files and Directories
- Access Files through FTP or directly (using PHP) to totally overcome permission and file ownership issues
- Upload or Download files just as you like
- Create and Extract Archives (ZIP, Tar, Tar/GZ, Tar/BZ)
- User Management with different permission levels like "View only" or "Edit" and "Admin"
- Installation Notes: you need to install PHP addon if not already done
default user is : admin password admin - Screenshots:
- Old Versions:
Removed- Sources and Credits :
Extplorer Web Site
1 Reply
- super_poussinVirtuosoupdated
