iearmand
Feb 03, 2012Aspirant
Filemanager (ajaxplorer) on NV+ v2
I've had my NV+ v2 for a week or so and it all but replaced my previous DIY nas. One of the things I still need to get is have some sort of filemanager like ajaxplorer or eXtplorer.
So my question is: If I install PHP 5.3 & phpmyadmin can I then go on to install (and use) ajaxplorer or eXtplorer?
- morten6883AspirantI need a file explorer as well. Have you found solution?
- iearmandAspirantUnfortunately no. NV+ v2 has limited answers & community support for addons so far...but heres hoping.
- morten6883AspirantOk, Thank you for your quick response :-)
- morten6883AspirantIt does not seem that the NV+ v2 gets any filemanagers addons so I have found a workaround using Midnight Commander through SSH access.
- Log in using SSH
Update the packages:apt-get update
Install Midnight Commander using following command:apt-get install mc
Start Midnight Commander by typing:mc
