radioguru6613
Aug 24, 2016Aspirant
File explorer and management for my ReadyNAS
Quick Question;
Is there an APP or add-on that will give me "File Explorer" functionality? I'm looking at a massive organizational project and on the 1st pass found that doing it from the standard GUI of the RN3220 is impossible as there is no true file manager integration where I can search a share for all files with an extension and then copy all to a new destination.
I would have thought this would be pretty standard as I had this in my old Synology products but not finding it here.
Short of running this from a client machine using search and then copy / paste, is there anything in the App family?
Thanks
1 Reply
- BrianL2NETGEAR Employee Retired
Hi radioguru6613,
Check the following add-ons.
Ajaxplorer
AjaxPlorer4
Pydio File Explorer
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
