assassin2k5
Jul 28, 2014Aspirant
FreeRadius Readynas os6 addon Not saving any changes
had my readynas 312 for about 4-6 months now during that time I had the freeradius server installed. I was able to add user and client details via the web UI. at the time I had no use for this add...
petercoolllll
Sep 05, 2015Aspirant
Hi ,
Where can find step by step setup guide for this Netgear free radius server ? Already try to setup , but fail . I want to use it for a wireless AP .
Trytohelp11
Sep 11, 2015Aspirant
Hi there,
Currently I have tested on a RN314 and it worked after I have flushed away everything and re-install it again. You might have to flush it. Also I have used Chrome web browser with a cleared cache/history.
The configuration is straight.
Add the user which he is the user logging in, with the password that will use to access the network.
Add the client whic is the IP address of the Access point. and the password that the Access Point will use to authenticate him self to the Radius
That it is as simple as it is. check the port that the radius will use, but usually the default if fine.
Good luck.
