mdgm-ntgr
Oct 12, 2013NETGEAR Employee Retired
General discussion on LMS for OS6
Please discuss LMS for OS6 here. Continues from http://www.readynas.com/forum/viewtopic.php?f=155&t=70937
- F_L_TutorWould it be possible to get a 7.7.4 or a 7.8.0 build for OS6?
- F_L_TutorAnother question.
Whats the best way to start over from scratch?
I had 7.7.3 installed but since I had some issues with it I tried to remove it. Removal failed though.
(But it was removed from the APP page)
So I tried to install 7.7.2 and it failed too.
The LMS package is also failing so it seems that I am stuck.
Rebooted the NAS and that didnt help.
EDIT: Now 7.7.2 magically appeared under APPS, so far so good.
But I still have the issue with not all plugins available.
Seems to be a cache issue:
http://forums.slimdevices.com/showthrea ... tings-page
Clearing /var/lib/squeezeboxserver/cache# didnt help
EDIT2: If you disable Extension Downloader plugin all 3rd party plugins disappears. Enable it to have them visible again - markwollGuideAbout to load this on my new 516 with 6.1.6.
Any gotcha's to be aware of? - fastfwdVirtuoso
markwoll wrote: About to load this on my new 516 with 6.1.6.
What is the "this" that you're about to load? Super-Poussin's addon for OS6, or something else? - vandermerweMastermarkwoll, assuming you are referring to the Logitech Media Server app, I have been running it for several months now without a problem on a 316.
I don't run any other apps. - markwollGuide
vandermerwe wrote: markwoll, assuming you are referring to the Logitech Media Server app, I have been running it for several months now without a problem on a 316.
This IS the answer I was looking for. Thanks. - JohnNultyApprenticeRunning fine on both my Duo v1 and RN312 (v7.7.3 with a modest 5,000 tracks). Connect normally to Squeezebox Duet, Boom, Radio, a PC-hosted SqueezePlay client, and a few Android clients. Not bothered about upgrading it - it does what I want it to do already. Thanks to S-P of course for making this all possible from 6.1.6, in the case of the RN312 :wink:
- markwollGuideThe LMS 7.8.0 version has been released.
There is a debian package for it but the size is much larger than Super Poussin's 7.7.3 package.
http://downloads.slimdevices.com/Logite ... er_v7.8.0/
Just wait for it? - F_L_TutorWow, a 7.8 Super Poussin package would be legendary :D
- super_poussinVirtuosotake a look in my community dropbox :)
You can find all my addons in a drop box : https://www.dropbox.com/sh/ie9pwk1wut72ias/p6_X2QeOIC
If you don not have dropbox installed use this link to install it, so I will have more space to share addons : http://db.tt/v4mPZg7l
