MWT
Sep 02, 2016Aspirant
Git addon?
Hi, I had to rebuild my nas and I was looking for the git 1.7.x package but it is no longer available. The respository is too old to use against the current git hub. Help! TIA mwt
- Sep 03, 2016
MWT wrote:
how do I get to RAID 6 with 2 redundant drives?
Switch out of X-RAID; add your new disk; then click on the new disk and you should see a "Add Parity" button.
After that you can re-click the X-RAID button.
The usual rule applies - you need the 4 largest disks to be the same size (after adding the new one).
MWT
Now that I like! 6 looks fantastic. One niggle - how do I get to RAID 6 with 2 redundant drives?
Sep 03, 2016Guru - Experienced User
- MWTSep 21, 2016Aspirant
That worked but it took over a week to resync 6 4tb drives!
- mdgm-ntgrSep 22, 2016NETGEAR Employee Retired
It's quicker to do a factory reset, destroy the volume and create a RAID-6 volume (best to call it "data" - no quotes) and re-enable X-RAID, but then you do have to restore the data from backup. So it could still take quite a while.
Which model do you have?
