mdgm-ntgr's avatar
mdgm-ntgr
NETGEAR Employee Retired
May 19, 2013
GPL diff b/w 6.0.4 and 6.0.5
As described on the GPL page, the GPL contains the software code for stuff NetGear uses in the firmware that is developed by 3rd parties. Nice useful downloads for developers, but it can be nice to compare the differences in 3rd party software code used between different versions of ReadyNAS OS. I wrote a script to do this a while back, and recently ran it to compare the GPL code for 6.0.4 to 6.0.5 (it should be noted that there is heaps of software code not subject to the GPL that is used by ReadyNAS OS and thus is not part of the GPL code and thus won't show up in the comparison below) and have pasted the results of my comparison below:
Files 6.0.4/bind9-9.8.4.dfsg.P1/bin/named/query.c and 6.0.5/bind9-9.8.4.dfsg.P1/bin/named/query.c differ
Files 6.0.4/bind9-9.8.4.dfsg.P1/config.h.in and 6.0.5/bind9-9.8.4.dfsg.P1/config.h.in differ
Files 6.0.4/bind9-9.8.4.dfsg.P1/configure and 6.0.5/bind9-9.8.4.dfsg.P1/configure differ
Files 6.0.4/bind9-9.8.4.dfsg.P1/configure.in and 6.0.5/bind9-9.8.4.dfsg.P1/configure.in differ
Files 6.0.4/bind9-9.8.4.dfsg.P1/debian/changelog and 6.0.5/bind9-9.8.4.dfsg.P1/debian/changelog differ
Files 6.0.4/bind9-9.8.4.dfsg.P1/debian/libbind-dev.install and 6.0.5/bind9-9.8.4.dfsg.P1/debian/libbind-dev.install differ
Files 6.0.4/btrfs-tools-0.20+20130117/btrfs-list.c and 6.0.5/btrfs-tools-0.20+20130117/btrfs-list.c differ
Files 6.0.4/btrfs-tools-0.20+20130117/debian/changelog and 6.0.5/btrfs-tools-0.20+20130117/debian/changelog differ
Files 6.0.4/btrfs-tools-0.20+20130117/debian/patches/02-ftbfs.patch and 6.0.5/btrfs-tools-0.20+20130117/debian/patches/02-ftbfs.patch differ
Only in 6.0.5/btrfs-tools-0.20+20130117/debian/patches: fix-subvolume-list-errors.patch
Files 6.0.4/btrfs-tools-0.20+20130117/debian/patches/series and 6.0.5/btrfs-tools-0.20+20130117/debian/patches/series differ
Files 6.0.4/btrfs-tools-0.20+20130117/.pc/applied-patches and 6.0.5/btrfs-tools-0.20+20130117/.pc/applied-patches differ
Only in 6.0.5/btrfs-tools-0.20+20130117/.pc: fix-subvolume-list-errors.patch
Files 6.0.4/cairo-1.12.2/debian/changelog and 6.0.5/cairo-1.12.2/debian/changelog differ
Files 6.0.4/cairo-1.12.2/debian/control and 6.0.5/cairo-1.12.2/debian/control differ
Only in 6.0.5/cairo-1.12.2/debian/patches: 07_cff-subsetting-Ignore-charset-for-non-cid-fonts.patch
Only in 6.0.5/cairo-1.12.2/debian/patches: 08_cff_convert_._to_locale_specific_decimal_point_befor.patch
Only in 6.0.5/cairo-1.12.2/debian/patches: 09_cff_use_correct_size_for_buffer.patch
Only in 6.0.5/cairo-1.12.2/debian/patches: 10_cff_subsetting_widths_can_be_floating_point.patch
Only in 6.0.5/cairo-1.12.2/debian/patches: 11_polygon-reduce_reduce_broken_stopped-edge_continuation.patch
Only in 6.0.5/cairo-1.12.2/debian/patches: intersect-dereference.diff
Files 6.0.4/cairo-1.12.2/debian/patches/series and 6.0.5/cairo-1.12.2/debian/patches/series differ
Only in 6.0.5/cairo-1.12.2/.pc: 07_cff-subsetting-Ignore-charset-for-non-cid-fonts.patch
Only in 6.0.5/cairo-1.12.2/.pc: 08_cff_convert_._to_locale_specific_decimal_point_befor.patch
Only in 6.0.5/cairo-1.12.2/.pc: 09_cff_use_correct_size_for_buffer.patch
Only in 6.0.5/cairo-1.12.2/.pc: 10_cff_subsetting_widths_can_be_floating_point.patch
Only in 6.0.5/cairo-1.12.2/.pc: 11_polygon-reduce_reduce_broken_stopped-edge_continuation.patch
Files 6.0.4/cairo-1.12.2/.pc/applied-patches and 6.0.5/cairo-1.12.2/.pc/applied-patches differ
Only in 6.0.5/cairo-1.12.2/.pc: intersect-dereference.diff
Files 6.0.4/cairo-1.12.2/src/cairo-cff-subset.c and 6.0.5/cairo-1.12.2/src/cairo-cff-subset.c differ
Files 6.0.4/cairo-1.12.2/src/cairo-polygon-intersect.c and 6.0.5/cairo-1.12.2/src/cairo-polygon-intersect.c differ
Files 6.0.4/cairo-1.12.2/src/cairo-polygon-reduce.c and 6.0.5/cairo-1.12.2/src/cairo-polygon-reduce.c differ
Files 6.0.4/cups-1.5.3/backend/usb-libusb.c and 6.0.5/cups-1.5.3/backend/usb-libusb.c differ
Files 6.0.4/cups-1.5.3/conf/mime.convs.in and 6.0.5/cups-1.5.3/conf/mime.convs.in differ
Files 6.0.4/cups-1.5.3/conf/mime.types and 6.0.5/cups-1.5.3/conf/mime.types differ
Files 6.0.4/cups-1.5.3/debian/changelog and 6.0.5/cups-1.5.3/debian/changelog differ
Files 6.0.4/cups-1.5.3/debian/control and 6.0.5/cups-1.5.3/debian/control differ
Only in 6.0.4/cups-1.5.3/debian: patched
Files 6.0.4/cups-1.5.3/debian/patches/airprint-support.patch and 6.0.5/cups-1.5.3/debian/patches/airprint-support.patch differ
Only in 6.0.5/cups-1.5.3/debian/patches: fix_kerberos_auth_local.patch
Only in 6.0.5/cups-1.5.3/debian/patches: fix_russian_japanese_templates.patch
Files 6.0.4/cups-1.5.3/debian/patches/series and 6.0.5/cups-1.5.3/debian/patches/series differ
Files 6.0.4/cups-1.5.3/debian/patches/split-configuration-files-STR4223.patch and 6.0.5/cups-1.5.3/debian/patches/split-configuration-files-STR4223.patch differ
Only in 6.0.5/cups-1.5.3/debian/patches: usb-backend-epson-stylus-photo-750.patch
Files 6.0.4/cups-1.5.3/doc/help/ref-cupsd-conf.html.in and 6.0.5/cups-1.5.3/doc/help/ref-cupsd-conf.html.in differ
Files 6.0.4/cups-1.5.3/doc/help/ref-cups-files-conf.html.in and 6.0.5/cups-1.5.3/doc/help/ref-cups-files-conf.html.in differ
Only in 6.0.5/cups-1.5.3/.pc/airprint-support.patch: conf
Only in 6.0.5/cups-1.5.3/.pc/airprint-support.patch/scheduler: printers.c
Files 6.0.4/cups-1.5.3/.pc/applied-patches and 6.0.5/cups-1.5.3/.pc/applied-patches differ
Files 6.0.4/cups-1.5.3/.pc/dnssd-reg-array-linear-search.patch/scheduler/dirsvc.c and 6.0.5/cups-1.5.3/.pc/dnssd-reg-array-linear-search.patch/scheduler/dirsvc.c differ
Only in 6.0.5/cups-1.5.3/.pc: fix_kerberos_auth_local.patch
Only in 6.0.5/cups-1.5.3/.pc: fix_russian_japanese_templates.patch
Files 6.0.4/cups-1.5.3/.pc/no-conffile-timestamp.patch/scheduler/dirsvc.c and 6.0.5/cups-1.5.3/.pc/no-conffile-timestamp.patch/scheduler/dirsvc.c differ
Files 6.0.4/cups-1.5.3/.pc/no-conffile-timestamp.patch/scheduler/printers.c and 6.0.5/cups-1.5.3/.pc/no-conffile-timestamp.patch/scheduler/printers.c differ
Files 6.0.4/cups-1.5.3/.pc/pstops-based-workflow-only-for-printing-ps-on-a-ps-printer.patch/conf/mime.convs.in and 6.0.5/cups-1.5.3/.pc/pstops-based-workflow-only-for-printing-ps-on-a-ps-printer.patch/conf/mime.convs.in differ
Only in 6.0.5/cups-1.5.3/.pc: usb-backend-epson-stylus-photo-750.patch
Files 6.0.4/cups-1.5.3/scheduler/client.c and 6.0.5/cups-1.5.3/scheduler/client.c differ
Files 6.0.4/cups-1.5.3/scheduler/dirsvc.c and 6.0.5/cups-1.5.3/scheduler/dirsvc.c differ
Files 6.0.4/cups-1.5.3/scheduler/printers.c and 6.0.5/cups-1.5.3/scheduler/printers.c differ
Files 6.0.4/cups-1.5.3/templates/ja/help-header.tmpl and 6.0.5/cups-1.5.3/templates/ja/help-header.tmpl differ
Files 6.0.4/cups-1.5.3/templates/ru/classes-header.tmpl and 6.0.5/cups-1.5.3/templates/ru/classes-header.tmpl differ
Files 6.0.4/cups-1.5.3/templates/ru/jobs-header.tmpl and 6.0.5/cups-1.5.3/templates/ru/jobs-header.tmpl differ
Files 6.0.4/cups-1.5.3/templates/ru/printers-header.tmpl and 6.0.5/cups-1.5.3/templates/ru/printers-header.tmpl differ
Files 6.0.4/curl-7.26.0/debian/changelog and 6.0.5/curl-7.26.0/debian/changelog differ
Only in 6.0.5/curl-7.26.0/debian/patches: 06_curl-tailmatch-CVE-2013-1944.patch
Only in 6.0.5/curl-7.26.0/debian/patches: 07_test1218-another-cookie-tailmatch-test.patch
Files 6.0.4/curl-7.26.0/debian/patches/series and 6.0.5/curl-7.26.0/debian/patches/series differ
Files 6.0.4/curl-7.26.0/lib/cookie.c and 6.0.5/curl-7.26.0/lib/cookie.c differ
Only in 6.0.5/curl-7.26.0/.pc: 06_curl-tailmatch-CVE-2013-1944.patch
Only in 6.0.5/curl-7.26.0/.pc: 07_test1218-another-cookie-tailmatch-test.patch
Files 6.0.4/curl-7.26.0/.pc/applied-patches and 6.0.5/curl-7.26.0/.pc/applied-patches differ
Files 6.0.4/curl-7.26.0/tests/data/Makefile.am and 6.0.5/curl-7.26.0/tests/data/Makefile.am differ
Files 6.0.4/curl-7.26.0/tests/data/Makefile.in and 6.0.5/curl-7.26.0/tests/data/Makefile.in differ
Only in 6.0.5/curl-7.26.0/tests/data: test1218
Only in 6.0.5: dpkg-1.16.10
Only in 6.0.4: dpkg-1.16.9
Files 6.0.4/e2fsprogs-1.42.5/debian/changelog and 6.0.5/e2fsprogs-1.42.5/debian/changelog differ
Only in 6.0.5/e2fsprogs-1.42.5/debian: e2fsck-static.preinst
Only in 6.0.5/e2fsprogs-1.42.5/debian: e2fsprogs.preinst
Files 6.0.4/gnutls26-2.12.20/debian/changelog and 6.0.5/gnutls26-2.12.20/debian/changelog differ
Files 6.0.4/gnutls26-2.12.20/debian/control and 6.0.5/gnutls26-2.12.20/debian/control differ
Only in 6.0.5/gnutls26-2.12.20/debian: gnutls-bin.examples
Only in 6.0.5/gnutls26-2.12.20/debian: gnutls-bin.install
Only in 6.0.5/gnutls26-2.12.20/debian: gnutls-bin.manpages
Only in 6.0.5/gnutls26-2.12.20/debian: guile-gnutls.install
Only in 6.0.5/gnutls26-2.12.20/debian: guile-gnutls.lintian-overrides
Only in 6.0.5/gnutls26-2.12.20/debian: guile-gnutls.README.Debian
Only in 6.0.4/gnutls26-2.12.20/debian: libgnutls26-dbg.install
Files 6.0.4/gnutls26-2.12.20/debian/rules and 6.0.5/gnutls26-2.12.20/debian/rules differ
Files 6.0.4/kmod-9/debian/changelog and 6.0.5/kmod-9/debian/changelog differ
Files 6.0.4/kmod-9/debian/control and 6.0.5/kmod-9/debian/control differ
Files 6.0.4/kmod-9/debian/patches/aliases_conf and 6.0.5/kmod-9/debian/patches/aliases_conf differ
Only in 6.0.5/kmod-9/debian/patches: bad_alias_assertion
Only in 6.0.5/kmod-9/debian/patches: dot_kcmdline
Files 6.0.4/kmod-9/debian/patches/series and 6.0.5/kmod-9/debian/patches/series differ
Files 6.0.4/kmod-9/extra/aliases.conf and 6.0.5/kmod-9/extra/aliases.conf differ
Files 6.0.4/kmod-9/libkmod/libkmod-config.c and 6.0.5/kmod-9/libkmod/libkmod-config.c differ
Files 6.0.4/kmod-9/.pc/applied-patches and 6.0.5/kmod-9/.pc/applied-patches differ
Only in 6.0.5/kmod-9/.pc: bad_alias_assertion
Files 6.0.4/kmod-9/.pc/blacklist_aliased/tools/modprobe.c and 6.0.5/kmod-9/.pc/blacklist_aliased/tools/modprobe.c differ
Only in 6.0.5/kmod-9/.pc: dot_kcmdline
Files 6.0.4/kmod-9/tools/modprobe.c and 6.0.5/kmod-9/tools/modprobe.c differ
Files 6.0.4/krb5-1.10.1+dfsg/debian/changelog and 6.0.5/krb5-1.10.1+dfsg/debian/changelog differ
Files 6.0.4/krb5-1.10.1+dfsg/debian/.git-dpm and 6.0.5/krb5-1.10.1+dfsg/debian/.git-dpm differ
Only in 6.0.5/krb5-1.10.1+dfsg/debian/patches: 0022-CVE-patch-from-krb5-1.10.1-dfsg-4-nmu1.patch
Only in 6.0.5/krb5-1.10.1+dfsg/debian/patches: 0023-Work-around-getaddrinfo-bug.patch
Only in 6.0.5/krb5-1.10.1+dfsg/debian/patches: 0024-KDC-TGS-REQ-null-deref-CVE-2013-1416.patch
Only in 6.0.4/krb5-1.10.1+dfsg/debian/patches: cve-2013-1016.patch
Files 6.0.4/krb5-1.10.1+dfsg/debian/patches/series and 6.0.5/krb5-1.10.1+dfsg/debian/patches/series differ
Only in 6.0.5/krb5-1.10.1+dfsg/.pc: 0022-CVE-patch-from-krb5-1.10.1-dfsg-4-nmu1.patch
Only in 6.0.5/krb5-1.10.1+dfsg/.pc: 0023-Work-around-getaddrinfo-bug.patch
Only in 6.0.5/krb5-1.10.1+dfsg/.pc: 0024-KDC-TGS-REQ-null-deref-CVE-2013-1416.patch
Files 6.0.4/krb5-1.10.1+dfsg/.pc/applied-patches and 6.0.5/krb5-1.10.1+dfsg/.pc/applied-patches differ
Only in 6.0.4/krb5-1.10.1+dfsg/.pc: cve-2013-1016.patch
Files 6.0.4/krb5-1.10.1+dfsg/src/kdc/do_tgs_req.c and 6.0.5/krb5-1.10.1+dfsg/src/kdc/do_tgs_req.c differ
Files 6.0.4/krb5-1.10.1+dfsg/src/lib/krb5/os/sn2princ.c and 6.0.5/krb5-1.10.1+dfsg/src/lib/krb5/os/sn2princ.c differ
Only in 6.0.4: linux-3.0.70
Only in 6.0.5: linux-3.0.74
Files 6.0.4/lvm2-2.02.95/daemons/dmeventd/libdevmapper-event.c and 6.0.5/lvm2-2.02.95/daemons/dmeventd/libdevmapper-event.c differ
Files 6.0.4/lvm2-2.02.95/debian/changelog and 6.0.5/lvm2-2.02.95/debian/changelog differ
Only in 6.0.5/lvm2-2.02.95/debian/patches: missing-dmeventd.patch
Files 6.0.4/lvm2-2.02.95/debian/patches/series and 6.0.5/lvm2-2.02.95/debian/patches/series differ
Only in 6.0.5/lvm2-2.02.95/debian/patches: upstream-fix-discard-1.patch
Only in 6.0.5/lvm2-2.02.95/debian/patches: upstream-fix-discard-2.patch
Only in 6.0.5/lvm2-2.02.95/debian/patches: upstream-fix-discard-3.patch
Files 6.0.4/lvm2-2.02.95/debian/rules and 6.0.5/lvm2-2.02.95/debian/rules differ
Files 6.0.4/lvm2-2.02.95/lib/activate/activate.c and 6.0.5/lvm2-2.02.95/lib/activate/activate.c differ
Files 6.0.4/lvm2-2.02.95/lib/metadata/lv_alloc.h and 6.0.5/lvm2-2.02.95/lib/metadata/lv_alloc.h differ
Files 6.0.4/lvm2-2.02.95/lib/metadata/lv_manip.c and 6.0.5/lvm2-2.02.95/lib/metadata/lv_manip.c differ
Files 6.0.4/lvm2-2.02.95/lib/metadata/mirror.c and 6.0.5/lvm2-2.02.95/lib/metadata/mirror.c differ
Files 6.0.4/lvm2-2.02.95/lib/metadata/pv_alloc.h and 6.0.5/lvm2-2.02.95/lib/metadata/pv_alloc.h differ
Files 6.0.4/lvm2-2.02.95/lib/metadata/pv_manip.c and 6.0.5/lvm2-2.02.95/lib/metadata/pv_manip.c differ
Files 6.0.4/lvm2-2.02.95/.pc/applied-patches and 6.0.5/lvm2-2.02.95/.pc/applied-patches differ
Only in 6.0.5/lvm2-2.02.95/.pc: missing-dmeventd.patch
Only in 6.0.5/lvm2-2.02.95/.pc: upstream-fix-discard-1.patch
Only in 6.0.5/lvm2-2.02.95/.pc: upstream-fix-discard-2.patch
Only in 6.0.5/lvm2-2.02.95/.pc: upstream-fix-discard-3.patch
Only in 6.0.5: minidlna-1.1.0
Only in 6.0.4: minidlna-1.1.0~rc3
Only in 6.0.4: netatalk-3.0.2
Only in 6.0.5: netatalk-3.0.3
Files 6.0.4/openldap-2.4.31/debian/changelog and 6.0.5/openldap-2.4.31/debian/changelog differ
Only in 6.0.5/openldap-2.4.31/debian/patches: bdb-deadlock.patch
Files 6.0.4/openldap-2.4.31/debian/patches/series and 6.0.5/openldap-2.4.31/debian/patches/series differ
Files 6.0.4/perl-5.14.2/debian/changelog and 6.0.5/perl-5.14.2/debian/changelog differ
Files 6.0.4/perl-5.14.2/debian/patches/fixes/64bitint-signedness-wraparound.diff and 6.0.5/perl-5.14.2/debian/patches/fixes/64bitint-signedness-wraparound.diff differ
Files 6.0.4/perl-5.14.2/debian/patches/fixes/digest-sha-doublefree.diff and 6.0.5/perl-5.14.2/debian/patches/fixes/digest-sha-doublefree.diff differ
Files 6.0.4/perl-5.14.2/debian/patches/fixes/encode-memleak.diff and 6.0.5/perl-5.14.2/debian/patches/fixes/encode-memleak.diff differ
Files 6.0.4/perl-5.14.2/debian/patches/fixes/hsplit-rehash.diff and 6.0.5/perl-5.14.2/debian/patches/fixes/hsplit-rehash.diff differ
Files 6.0.4/perl-5.14.2/debian/patches/fixes/maketext-code-execution.diff and 6.0.5/perl-5.14.2/debian/patches/fixes/maketext-code-execution.diff differ
Files 6.0.4/perl-5.14.2/debian/patches/fixes/stdin-sigchld.diff and 6.0.5/perl-5.14.2/debian/patches/fixes/stdin-sigchld.diff differ
Files 6.0.4/perl-5.14.2/debian/patches/fixes/storable-security-warning.diff and 6.0.5/perl-5.14.2/debian/patches/fixes/storable-security-warning.diff differ
Files 6.0.4/perl-5.14.2/dist/Locale-Maketext/ChangeLog and 6.0.5/perl-5.14.2/dist/Locale-Maketext/ChangeLog differ
Files 6.0.4/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext/GutsLoader.pm and 6.0.5/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext/GutsLoader.pm differ
Files 6.0.4/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext/Guts.pm and 6.0.5/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext/Guts.pm differ
Files 6.0.4/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext/TPJ13.pod and 6.0.5/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext/TPJ13.pod differ
Files 6.0.4/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext.pm and 6.0.5/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext.pm differ
Files 6.0.4/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext.pod and 6.0.5/perl-5.14.2/dist/Locale-Maketext/lib/Locale/Maketext.pod differ
Only in 6.0.5/perl-5.14.2/dist/Locale-Maketext/t: 00_load.t
Files 6.0.4/perl-5.14.2/dist/Locale-Maketext/t/09_compile.t and 6.0.5/perl-5.14.2/dist/Locale-Maketext/t/09_compile.t differ
Only in 6.0.5/perl-5.14.2/dist/Locale-Maketext/t: pod.t
Only in 6.0.5/perl-5.14.2/.pc/fixes/maketext-code-execution.diff/dist/Locale-Maketext: ChangeLog
Only in 6.0.5/perl-5.14.2/.pc/fixes/maketext-code-execution.diff/dist/Locale-Maketext/lib/Locale: Maketext
Only in 6.0.5/perl-5.14.2/.pc/fixes/maketext-code-execution.diff/dist/Locale-Maketext/lib/Locale: Maketext.pod
Only in 6.0.5/perl-5.14.2/.pc/fixes/maketext-code-execution.diff/dist/Locale-Maketext: t
Files 6.0.4/procps-3.3.3/debian/changelog and 6.0.5/procps-3.3.3/debian/changelog differ
Only in 6.0.5/procps-3.3.3/debian/patches: bts702965-biggerbuff
Files 6.0.4/procps-3.3.3/debian/patches/series and 6.0.5/procps-3.3.3/debian/patches/series differ
Files 6.0.4/procps-3.3.3/.pc/applied-patches and 6.0.5/procps-3.3.3/.pc/applied-patches differ
Only in 6.0.5/procps-3.3.3/.pc: bts702965-biggerbuff
Files 6.0.4/procps-3.3.3/proc/readproc.c and 6.0.5/procps-3.3.3/proc/readproc.c differ
Only in 6.0.4: samba4-4.0.3
Only in 6.0.5: samba4-4.0.5
Only in 6.0.5: syslinux-4.06~pre11
Only in 6.0.4: tevent-0.9.17
Only in 6.0.5: tevent-0.9.18
Files 6.0.4/tzdata-2013b/debian/changelog and 6.0.5/tzdata-2013b/debian/changelog differ
Files 6.0.4/tzdata-2013b/debian/po/cs.po and 6.0.5/tzdata-2013b/debian/po/cs.po differ
Files 6.0.4/tzdata-2013b/debian/po/da.po and 6.0.5/tzdata-2013b/debian/po/da.po differ
Files 6.0.4/tzdata-2013b/debian/po/de.po and 6.0.5/tzdata-2013b/debian/po/de.po differ
Files 6.0.4/tzdata-2013b/debian/po/es.po and 6.0.5/tzdata-2013b/debian/po/es.po differ
Files 6.0.4/tzdata-2013b/debian/po/eu.po and 6.0.5/tzdata-2013b/debian/po/eu.po differ
Files 6.0.4/tzdata-2013b/debian/po/fr.po and 6.0.5/tzdata-2013b/debian/po/fr.po differ
Files 6.0.4/tzdata-2013b/debian/po/gl.po and 6.0.5/tzdata-2013b/debian/po/gl.po differ
Files 6.0.4/tzdata-2013b/debian/po/he.po and 6.0.5/tzdata-2013b/debian/po/he.po differ
Files 6.0.4/tzdata-2013b/debian/po/hu.po and 6.0.5/tzdata-2013b/debian/po/hu.po differ
Files 6.0.4/tzdata-2013b/debian/po/it.po and 6.0.5/tzdata-2013b/debian/po/it.po differ
Files 6.0.4/tzdata-2013b/debian/po/ja.po and 6.0.5/tzdata-2013b/debian/po/ja.po differ
Files 6.0.4/tzdata-2013b/debian/po/pt_BR.po and 6.0.5/tzdata-2013b/debian/po/pt_BR.po differ
Files 6.0.4/tzdata-2013b/debian/po/pt.po and 6.0.5/tzdata-2013b/debian/po/pt.po differ
Files 6.0.4/tzdata-2013b/debian/po/ru.po and 6.0.5/tzdata-2013b/debian/po/ru.po differ
Files 6.0.4/tzdata-2013b/debian/po/sv.po and 6.0.5/tzdata-2013b/debian/po/sv.po differ
Files 6.0.4/udev-175/debian/changelog and 6.0.5/udev-175/debian/changelog differ
Files 6.0.4/udev-175/debian/patches/extra_modprobeconf and 6.0.5/udev-175/debian/patches/extra_modprobeconf differ
Files 6.0.4/udev-175/extra/fbdev-blacklist.conf and 6.0.5/udev-175/extra/fbdev-blacklist.conf differ
Files 6.0.4/udev-175/extra/make-fbdev-blacklist and 6.0.5/udev-175/extra/make-fbdev-blacklist differ
ProSupport for Business
