mdgm-ntgr's avatar
mdgm-ntgr
NETGEAR Employee Retired
Aug 27, 2013
GPL diff b/w 6.0.8 and 6.1.1
As described on the GPL page, the GPL contains the software code for stuff NetGear uses in the firmware that is developed by 3rd parties. Nice useful downloads for developers, but it can be nice to compare the differences in 3rd party software code used between different versions of ReadyNAS OS. I wrote a script to do this a while back, and recently ran it to compare the GPL code for 6.0.8 to 6.1.1 (it should be noted that there is heaps of software code not subject to the GPL that is used by ReadyNAS OS and thus is not part of the GPL code and thus won't show up in the comparison below) and have pasted the results of my comparison below:
Only in 6.0.8: apache2-2.2.22
Only in 6.1.1: apache2-2.2.25
Only in 6.0.8: apt-0.9.7.8
Only in 6.1.1: apt-0.9.7.9
Only in 6.0.8: base-files-7.1
Only in 6.1.1: base-files-7.1wheezy1
Only in 6.1.1: boost1.49-1.49.0
Only in 6.0.8: btrfs-tools-0.20+20130117
Only in 6.1.1: btrfs-tools-0.20+20130705
Only in 6.0.8: buildroot-2013.02
Only in 6.1.1: buildroot-2013.05
Only in 6.0.8: cifs-utils-5.5
Only in 6.1.1: cifs-utils-6.1
Only in 6.0.8: curl-7.26.0
Only in 6.1.1: curl-7.31.0
Files 6.0.8/cyrus-sasl2-2.1.25.dfsg1/debian/changelog and 6.1.1/cyrus-sasl2-2.1.25.dfsg1/debian/changelog differ
Files 6.0.8/cyrus-sasl2-2.1.25.dfsg1/debian/gbp.conf and 6.1.1/cyrus-sasl2-2.1.25.dfsg1/debian/gbp.conf differ
Files 6.0.8/cyrus-sasl2-2.1.25.dfsg1/debian/patches/0034-fix_dovecot_authentication.patch and 6.1.1/cyrus-sasl2-2.1.25.dfsg1/debian/patches/0034-fix_dovecot_authentication.patch differ
Only in 6.1.1/cyrus-sasl2-2.1.25.dfsg1/debian/patches: 0038-send_imap_logout.patch
Only in 6.1.1/cyrus-sasl2-2.1.25.dfsg1/debian/patches: 0039-fix-canonuser-ldapdb-garbage-in-out-buffer.patch
Files 6.0.8/cyrus-sasl2-2.1.25.dfsg1/debian/patches/series and 6.1.1/cyrus-sasl2-2.1.25.dfsg1/debian/patches/series differ
Only in 6.1.1/cyrus-sasl2-2.1.25.dfsg1/.pc: 0038-send_imap_logout.patch
Only in 6.1.1/cyrus-sasl2-2.1.25.dfsg1/.pc: 0039-fix-canonuser-ldapdb-garbage-in-out-buffer.patch
Files 6.0.8/cyrus-sasl2-2.1.25.dfsg1/.pc/applied-patches and 6.1.1/cyrus-sasl2-2.1.25.dfsg1/.pc/applied-patches differ
Files 6.0.8/cyrus-sasl2-2.1.25.dfsg1/plugins/ldapdb.c and 6.1.1/cyrus-sasl2-2.1.25.dfsg1/plugins/ldapdb.c differ
Files 6.0.8/cyrus-sasl2-2.1.25.dfsg1/saslauthd/auth_rimap.c and 6.1.1/cyrus-sasl2-2.1.25.dfsg1/saslauthd/auth_rimap.c differ
Only in 6.1.1: dbus-1.6.12
Only in 6.0.8: dbus-1.6.8
Only in 6.0.8: ffmpeg-1.0.1
Only in 6.1.1: ffmpeg-1.2.2
Files 6.0.8/forked-daapd-0.19ntgr/debian/changelog and 6.1.1/forked-daapd-0.19ntgr/debian/changelog differ
Files 6.0.8/forked-daapd-0.19ntgr/debian/control and 6.1.1/forked-daapd-0.19ntgr/debian/control differ
Only in 6.1.1/forked-daapd-0.19ntgr/debian/patches: add-local-audio-disable-option.patch
Only in 6.1.1/forked-daapd-0.19ntgr/debian/patches: add-swresample-support.patch
Only in 6.1.1/forked-daapd-0.19ntgr/debian/patches: fix-atv-v2-8-second-stop.patch
Only in 6.1.1/forked-daapd-0.19ntgr/debian/patches: fix-crash-with-empty-buffer.patch
Files 6.0.8/forked-daapd-0.19ntgr/debian/patches/series and 6.1.1/forked-daapd-0.19ntgr/debian/patches/series differ
Only in 6.1.1/forked-daapd-0.19ntgr/debian/patches: set-default-name-to-Disabled.patch
Only in 6.1.1/forked-daapd-0.19ntgr/debian/patches: support-android-remotes.patch
Only in 6.1.1/forked-daapd-0.19ntgr/.pc: add-local-audio-disable-option.patch
Only in 6.1.1/forked-daapd-0.19ntgr/.pc: add-swresample-support.patch
Files 6.0.8/forked-daapd-0.19ntgr/.pc/applied-patches and 6.1.1/forked-daapd-0.19ntgr/.pc/applied-patches differ
Only in 6.1.1/forked-daapd-0.19ntgr/.pc: fix-atv-v2-8-second-stop.patch
Only in 6.1.1/forked-daapd-0.19ntgr/.pc: fix-crash-with-empty-buffer.patch
Only in 6.1.1/forked-daapd-0.19ntgr/.pc: set-default-name-to-Disabled.patch
Only in 6.1.1/forked-daapd-0.19ntgr/.pc: support-android-remotes.patch
Files 6.0.8/forked-daapd-0.19ntgr/src/conffile.c and 6.1.1/forked-daapd-0.19ntgr/src/conffile.c differ
Files 6.0.8/forked-daapd-0.19ntgr/src/httpd_dacp.c and 6.1.1/forked-daapd-0.19ntgr/src/httpd_dacp.c differ
Files 6.0.8/forked-daapd-0.19ntgr/src/Makefile.in and 6.1.1/forked-daapd-0.19ntgr/src/Makefile.in differ
Files 6.0.8/forked-daapd-0.19ntgr/src/misc.c and 6.1.1/forked-daapd-0.19ntgr/src/misc.c differ
Files 6.0.8/forked-daapd-0.19ntgr/src/misc.h and 6.1.1/forked-daapd-0.19ntgr/src/misc.h differ
Files 6.0.8/forked-daapd-0.19ntgr/src/player.c and 6.1.1/forked-daapd-0.19ntgr/src/player.c differ
Files 6.0.8/forked-daapd-0.19ntgr/src/player.h and 6.1.1/forked-daapd-0.19ntgr/src/player.h differ
Files 6.0.8/forked-daapd-0.19ntgr/src/raop.c and 6.1.1/forked-daapd-0.19ntgr/src/raop.c differ
Files 6.0.8/forked-daapd-0.19ntgr/src/transcode.c and 6.1.1/forked-daapd-0.19ntgr/src/transcode.c differ
Files 6.0.8/gnutls26-2.12.20/debian/changelog and 6.1.1/gnutls26-2.12.20/debian/changelog differ
Only in 6.1.1/gnutls26-2.12.20/debian/patches: 36_sanitycheck.diff
Files 6.0.8/gnutls26-2.12.20/debian/patches/series and 6.1.1/gnutls26-2.12.20/debian/patches/series differ
Files 6.0.8/gnutls26-2.12.20/lib/gnutls_cipher.c and 6.1.1/gnutls26-2.12.20/lib/gnutls_cipher.c differ
Only in 6.1.1/gnutls26-2.12.20/.pc: 36_sanitycheck.diff
Files 6.0.8/gnutls26-2.12.20/.pc/applied-patches and 6.1.1/gnutls26-2.12.20/.pc/applied-patches differ
Only in 6.1.1: lame-3.99.5+repack1
Only in 6.0.8: ldb-1.1.15
Only in 6.1.1: ldb-1.1.16
Only in 6.0.8: libbsd-0.4.2
Only in 6.1.1: libbsd-0.5.2
Files 6.0.8/libnss-myhostname-0.3/debian/changelog and 6.1.1/libnss-myhostname-0.3/debian/changelog differ
Only in 6.1.1/libnss-myhostname-0.3/debian/patches: 0005-Ignore-link-local-addresses.patch
Files 6.0.8/libnss-myhostname-0.3/debian/patches/series and 6.1.1/libnss-myhostname-0.3/debian/patches/series differ
Files 6.0.8/libnss-myhostname-0.3/netlink.c and 6.1.1/libnss-myhostname-0.3/netlink.c differ
Only in 6.1.1/libnss-myhostname-0.3/.pc: 0005-Ignore-link-local-addresses.patch
Files 6.0.8/libnss-myhostname-0.3/.pc/applied-patches and 6.1.1/libnss-myhostname-0.3/.pc/applied-patches differ
Only in 6.0.8: linux-3.0.79
Only in 6.1.1: linux-3.0.87
Only in 6.0.8: lm-sensors-3.3.2
Only in 6.1.1: lm-sensors-3.3.4
Only in 6.0.8: lsb-4.1+Debian8
Only in 6.1.1: lsb-4.1+Debian8+deb7u1
Only in 6.1.1: lzo2-2.06
Files 6.0.8/minidlna-1.1.0/debian/changelog and 6.1.1/minidlna-1.1.0/debian/changelog differ
Files 6.0.8/minidlna-1.1.0/debian/control and 6.1.1/minidlna-1.1.0/debian/control differ
Only in 6.1.1/minidlna-1.1.0/debian/patches: new-netgear-icon.patch
Files 6.0.8/minidlna-1.1.0/debian/patches/series and 6.1.1/minidlna-1.1.0/debian/patches/series differ
Only in 6.1.1/minidlna-1.1.0/debian/patches: sony-set-ci-on-fake-res.patch
Files 6.0.8/minidlna-1.1.0/debian/rules and 6.1.1/minidlna-1.1.0/debian/rules differ
Files 6.0.8/minidlna-1.1.0/icons.c and 6.1.1/minidlna-1.1.0/icons.c differ
Files 6.0.8/minidlna-1.1.0/.pc/applied-patches and 6.1.1/minidlna-1.1.0/.pc/applied-patches differ
Only in 6.1.1/minidlna-1.1.0/.pc: new-netgear-icon.patch
Only in 6.1.1/minidlna-1.1.0/.pc: sony-set-ci-on-fake-res.patch
Files 6.0.8/minidlna-1.1.0/upnpsoap.c and 6.1.1/minidlna-1.1.0/upnpsoap.c differ
Only in 6.0.8: netatalk-3.0.3
Only in 6.1.1: netatalk-3.0.4
Only in 6.1.1: net-tools-1.60
Files 6.0.8/nfs-utils-1.2.6/debian/changelog and 6.1.1/nfs-utils-1.2.6/debian/changelog differ
Only in 6.1.1/nfs-utils-1.2.6/debian/patches: 20-auth_unix_ip.patch
Only in 6.1.1/nfs-utils-1.2.6/debian/patches: 21-avoid-DNS-reverse-resolution.patch
Only in 6.1.1/nfs-utils-1.2.6/debian/patches: 22-use-default-domain.patch
Only in 6.1.1/nfs-utils-1.2.6/debian/patches: 23-getoptR.patch
Files 6.0.8/nfs-utils-1.2.6/debian/patches/series and 6.1.1/nfs-utils-1.2.6/debian/patches/series differ
Only in 6.1.1/nfs-utils-1.2.6/.pc: 20-auth_unix_ip.patch
Only in 6.1.1/nfs-utils-1.2.6/.pc: 21-avoid-DNS-reverse-resolution.patch
Only in 6.1.1/nfs-utils-1.2.6/.pc: 22-use-default-domain.patch
Only in 6.1.1/nfs-utils-1.2.6/.pc: 23-getoptR.patch
Files 6.0.8/nfs-utils-1.2.6/.pc/applied-patches and 6.1.1/nfs-utils-1.2.6/.pc/applied-patches differ
Files 6.0.8/nfs-utils-1.2.6/utils/gssd/gssd.c and 6.1.1/nfs-utils-1.2.6/utils/gssd/gssd.c differ
Files 6.0.8/nfs-utils-1.2.6/utils/gssd/gssd.man and 6.1.1/nfs-utils-1.2.6/utils/gssd/gssd.man differ
Files 6.0.8/nfs-utils-1.2.6/utils/gssd/gssd_proc.c and 6.1.1/nfs-utils-1.2.6/utils/gssd/gssd_proc.c differ
Files 6.0.8/nfs-utils-1.2.6/utils/gssd/gss_util.h and 6.1.1/nfs-utils-1.2.6/utils/gssd/gss_util.h differ
Files 6.0.8/nfs-utils-1.2.6/utils/mountd/cache.c and 6.1.1/nfs-utils-1.2.6/utils/mountd/cache.c differ
Files 6.0.8/nfs-utils-1.2.6/utils/nfsidmap/nfsidmap.c and 6.1.1/nfs-utils-1.2.6/utils/nfsidmap/nfsidmap.c differ
Only in 6.0.8: samba4-4.0.5
Only in 6.1.1: samba4-4.0.7
Only in 6.1.1: smartmontools-6.1
Only in 6.1.1: snapper-0.1.5
Only in 6.0.8: sqlite3-3.7.13
Only in 6.1.1: sqlite3-3.7.17
Files 6.0.8/systemd-44/debian/changelog and 6.1.1/systemd-44/debian/changelog differ
Files 6.0.8/systemd-44/debian/libsystemd-journal0.symbols and 6.1.1/systemd-44/debian/libsystemd-journal0.symbols differ
Files 6.0.8/systemd-44/debian/libsystemd-login0.symbols and 6.1.1/systemd-44/debian/libsystemd-login0.symbols differ
Files 6.0.8/systemd-44/src/core/device.c and 6.1.1/systemd-44/src/core/device.c differ
Files 6.0.8/systemd-44/src/core/transaction.c and 6.1.1/systemd-44/src/core/transaction.c differ
Files 6.0.8/systemd-44/src/cryptsetup/cryptsetup-generator.c and 6.1.1/systemd-44/src/cryptsetup/cryptsetup-generator.c differ
Files 6.0.8/systemd-44/tmpfiles.d/systemd.conf and 6.1.1/systemd-44/tmpfiles.d/systemd.conf differ
Files 6.0.8/systemd-44/units/local-fs.target and 6.1.1/systemd-44/units/local-fs.target differ
Only in 6.0.8: tdb-1.2.11
Only in 6.1.1: tdb-1.2.12
Only in 6.0.8: tzdata-2013b
Only in 6.1.1: tzdata-2013c
Files 6.0.8/util-linux-2.20.1/aclocal.m4 and 6.1.1/util-linux-2.20.1/aclocal.m4 differ
Files 6.0.8/util-linux-2.20.1/config/compile and 6.1.1/util-linux-2.20.1/config/compile differ
Files 6.0.8/util-linux-2.20.1/config/config.guess and 6.1.1/util-linux-2.20.1/config/config.guess differ
Files 6.0.8/util-linux-2.20.1/config/config.sub and 6.1.1/util-linux-2.20.1/config/config.sub differ
Files 6.0.8/util-linux-2.20.1/config/depcomp and 6.1.1/util-linux-2.20.1/config/depcomp differ
Files 6.0.8/util-linux-2.20.1/config/install-sh and 6.1.1/util-linux-2.20.1/config/install-sh differ
Files 6.0.8/util-linux-2.20.1/config/ltmain.sh and 6.1.1/util-linux-2.20.1/config/ltmain.sh differ
Files 6.0.8/util-linux-2.20.1/config/missing and 6.1.1/util-linux-2.20.1/config/missing differ
Files 6.0.8/util-linux-2.20.1/config/mkinstalldirs and 6.1.1/util-linux-2.20.1/config/mkinstalldirs differ
Files 6.0.8/util-linux-2.20.1/config.h.in and 6.1.1/util-linux-2.20.1/config.h.in differ
Only in 6.1.1/util-linux-2.20.1: config.log
Files 6.0.8/util-linux-2.20.1/configure and 6.1.1/util-linux-2.20.1/configure differ
Files 6.0.8/util-linux-2.20.1/debian/changelog and 6.1.1/util-linux-2.20.1/debian/changelog differ
Files 6.0.8/util-linux-2.20.1/disk-utils/Makefile.in and 6.1.1/util-linux-2.20.1/disk-utils/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/fdisk/Makefile.in and 6.1.1/util-linux-2.20.1/fdisk/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/fsck/Makefile.in and 6.1.1/util-linux-2.20.1/fsck/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/getopt/Makefile.in and 6.1.1/util-linux-2.20.1/getopt/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/hwclock/Makefile.in and 6.1.1/util-linux-2.20.1/hwclock/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/include/Makefile.in and 6.1.1/util-linux-2.20.1/include/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/INSTALL and 6.1.1/util-linux-2.20.1/INSTALL differ
Files 6.0.8/util-linux-2.20.1/lib/Makefile.in and 6.1.1/util-linux-2.20.1/lib/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libblkid/docs/Makefile.in and 6.1.1/util-linux-2.20.1/libblkid/docs/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libblkid/libblkid.3 and 6.1.1/util-linux-2.20.1/libblkid/libblkid.3 differ
Files 6.0.8/util-linux-2.20.1/libblkid/Makefile.in and 6.1.1/util-linux-2.20.1/libblkid/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libblkid/samples/Makefile.in and 6.1.1/util-linux-2.20.1/libblkid/samples/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/blkidP.h and 6.1.1/util-linux-2.20.1/libblkid/src/blkidP.h differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/cache.c and 6.1.1/util-linux-2.20.1/libblkid/src/cache.c differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/Makefile.in and 6.1.1/util-linux-2.20.1/libblkid/src/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/partitions/Makefile.in and 6.1.1/util-linux-2.20.1/libblkid/src/partitions/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/read.c and 6.1.1/util-linux-2.20.1/libblkid/src/read.c differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/save.c and 6.1.1/util-linux-2.20.1/libblkid/src/save.c differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/superblocks/Makefile.am and 6.1.1/util-linux-2.20.1/libblkid/src/superblocks/Makefile.am differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/superblocks/Makefile.in and 6.1.1/util-linux-2.20.1/libblkid/src/superblocks/Makefile.in differ
Only in 6.1.1/util-linux-2.20.1/libblkid/src/superblocks: netgear_raid.c
Files 6.0.8/util-linux-2.20.1/libblkid/src/superblocks/superblocks.c and 6.1.1/util-linux-2.20.1/libblkid/src/superblocks/superblocks.c differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/superblocks/superblocks.h and 6.1.1/util-linux-2.20.1/libblkid/src/superblocks/superblocks.h differ
Files 6.0.8/util-linux-2.20.1/libblkid/src/topology/Makefile.in and 6.1.1/util-linux-2.20.1/libblkid/src/topology/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libmount/docs/Makefile.in and 6.1.1/util-linux-2.20.1/libmount/docs/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libmount/Makefile.in and 6.1.1/util-linux-2.20.1/libmount/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libmount/samples/Makefile.in and 6.1.1/util-linux-2.20.1/libmount/samples/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libmount/src/cache.c and 6.1.1/util-linux-2.20.1/libmount/src/cache.c differ
Files 6.0.8/util-linux-2.20.1/libmount/src/Makefile.in and 6.1.1/util-linux-2.20.1/libmount/src/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libuuid/Makefile.in and 6.1.1/util-linux-2.20.1/libuuid/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libuuid/man/Makefile.in and 6.1.1/util-linux-2.20.1/libuuid/man/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/libuuid/src/Makefile.in and 6.1.1/util-linux-2.20.1/libuuid/src/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/login-utils/Makefile.in and 6.1.1/util-linux-2.20.1/login-utils/Makefile.in differ
Only in 6.1.1/util-linux-2.20.1/m4: codeset.m4
Only in 6.1.1/util-linux-2.20.1/m4: glibc21.m4
Only in 6.1.1/util-linux-2.20.1/m4: intdiv0.m4
Only in 6.1.1/util-linux-2.20.1/m4: intmax.m4
Only in 6.1.1/util-linux-2.20.1/m4: inttypes_h.m4
Only in 6.1.1/util-linux-2.20.1/m4: inttypes.m4
Only in 6.1.1/util-linux-2.20.1/m4: inttypes-pri.m4
Only in 6.1.1/util-linux-2.20.1/m4: isc-posix.m4
Only in 6.1.1/util-linux-2.20.1/m4: lcmessage.m4
Files 6.0.8/util-linux-2.20.1/m4/libtool.m4 and 6.1.1/util-linux-2.20.1/m4/libtool.m4 differ
Only in 6.1.1/util-linux-2.20.1/m4: longdouble.m4
Only in 6.1.1/util-linux-2.20.1/m4: longlong.m4
Files 6.0.8/util-linux-2.20.1/m4/ltoptions.m4 and 6.1.1/util-linux-2.20.1/m4/ltoptions.m4 differ
Files 6.0.8/util-linux-2.20.1/m4/ltversion.m4 and 6.1.1/util-linux-2.20.1/m4/ltversion.m4 differ
Only in 6.1.1/util-linux-2.20.1/m4: printf-posix.m4
Only in 6.1.1/util-linux-2.20.1/m4: signed.m4
Only in 6.1.1/util-linux-2.20.1/m4: size_max.m4
Only in 6.1.1/util-linux-2.20.1/m4: stdint_h.m4
Only in 6.1.1/util-linux-2.20.1/m4: uintmax_t.m4
Only in 6.1.1/util-linux-2.20.1/m4: ulonglong.m4
Only in 6.1.1/util-linux-2.20.1/m4: wchar_t.m4
Only in 6.1.1/util-linux-2.20.1/m4: wint_t.m4
Only in 6.1.1/util-linux-2.20.1/m4: xsize.m4
Files 6.0.8/util-linux-2.20.1/Makefile.in and 6.1.1/util-linux-2.20.1/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/man/ru/Makefile.in and 6.1.1/util-linux-2.20.1/man/ru/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/misc-utils/blkid.8 and 6.1.1/util-linux-2.20.1/misc-utils/blkid.8 differ
Files 6.0.8/util-linux-2.20.1/misc-utils/blkid.c and 6.1.1/util-linux-2.20.1/misc-utils/blkid.c differ
Files 6.0.8/util-linux-2.20.1/misc-utils/Makefile.in and 6.1.1/util-linux-2.20.1/misc-utils/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/mount/Makefile.in and 6.1.1/util-linux-2.20.1/mount/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/partx/Makefile.in and 6.1.1/util-linux-2.20.1/partx/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/po/Makefile.in.in and 6.1.1/util-linux-2.20.1/po/Makefile.in.in differ
Only in 6.1.1/util-linux-2.20.1/po: Makevars.template
Files 6.0.8/util-linux-2.20.1/schedutils/Makefile.in and 6.1.1/util-linux-2.20.1/schedutils/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/sys-utils/Makefile.in and 6.1.1/util-linux-2.20.1/sys-utils/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/term-utils/Makefile.in and 6.1.1/util-linux-2.20.1/term-utils/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/tests/helpers/Makefile.in and 6.1.1/util-linux-2.20.1/tests/helpers/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/tests/Makefile.in and 6.1.1/util-linux-2.20.1/tests/Makefile.in differ
Files 6.0.8/util-linux-2.20.1/text-utils/Makefile.in and 6.1.1/util-linux-2.20.1/text-utils/Makefile.in differ
ProSupport for Business
