Jophus
Jan 17, 2021Luminary
HELP - RN316 reset means I lost super poussin LMS - where is lms_1.0.9_all.deb?
Hello Team. Once again I am facing a complete rebuild of my RN316 due to a failed disk replacement/upgrade and expansion. It should have worked, but didn't an instead gave me two volumes - one wi...
- Jan 18, 2021
There's a link here that is still functioning: https://forums.slimdevices.com/showthread.php?112880-NETGEAR-ReadyNAS-LMS-install-problems&p=987438&viewfull=1#post987438
Jan 18, 2021Guru - Experienced User
Jophus
Jan 18, 2021Luminary
I seached and searched slim forum but could not find it! You are a star and I really appreciate your help!
ReadyNAS lives to fight another day!
- StephenBJan 18, 2021Guru - Experienced User
I'm glad I could help.
- SandsharkJan 18, 2021Sensei
Since the user on that forum stated he is moving to another brand of NAS, it would be helpful if it were made available elsewhere for the future. Relying on individual users' Dropboxes and such isn't the most reliable way to do it, so somewhere else would be better. I'm not an LMS user myself, and whoever maintains it should be so they can add any comments if it stops working with an OS or LMS update.
- StephenBJan 19, 2021Guru - Experienced User
True, but that's not on Netgear, it's on super_poussin. I don't think this app was ever hosted by Netgear.
FWIW, when they cleaned up the app store some years ago (removing incompatible apps), they archived the incompatible apps here: https://github.com/ReadyNAS/sdk/wiki/App-Archive But this particular app isn't in that archive.
In any event, I suggest making sure you keep a copy of any third party app that you install.
