Felson
Mar 05, 2019Tutor
HOW-TO: Compile Custom Kernel Modules ReadyNASOS 6.9.X
I am going to do this example for the 'ppp' modules. If you need other modules, make adjustments as nessasary.
sudo apt update
sudo apt install libncurses5-dev
sudo apt install build-essential
s...
Retired_Member
Mar 06, 2019Hi Felson , thanks for posting this. Great to know, that this is possible. Kind regards
