psnick
Feb 27, 2016Aspirant
How to enable curl on readynas 102
How do in enable curl on my readynas 102. I cant find any answer anywhere. I tried to install curl through winscp through apt command but was not successfull. please help me with this
- Feb 29, 2016
Ah. What about this?:
# apt-get install php5-curl
You could try adding
extension=curl.so
to your php.ini file.
psnick
Feb 29, 2016Aspirant
I did this and it says
root@iSchool:~# apt-get install curl
Reading package lists... Done
Building dependency tree
Reading state information... Done
curl is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
As i am developing a php application. my question is how to enable it. I cant find it in php.ini file.
mdgm-ntgr
Feb 29, 2016NETGEAR Employee Retired
extension=curl.so
