devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys, For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it. 1. Backup all the .conf files in /etc/frontview/apache 2....
Event_Horizon
Jul 25, 2010Aspirant
Hi
That is the beauty of my solution. You do not have to enable root SSH access and you don't need to play around with apache or any of the system files so the chances of trashing the system are negligible. It is therefore unlikely that you will need to do a hardware re-install with this solution.
You do not need to create any additional files in the addons directory and the only system file that is changed is Virtual.conf which is changed within frontview.
Cheers
Phil
Cheers
Phil
