devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys, For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it. 1. Backup all the .conf files in /etc/frontview/apache 2....
ericclaeren
Feb 26, 2012Aspirant
Hi Stefan,
Thanks, I tried your apache Frontview version, but unfortunately they did not work for me, could not get apache running, Tried to move some parts around, but I'm not comfortable with that and didn't got it working.
Really thought when buying this NAS running a web server would be a piece of cake, just like a regular linux apache2 setup. So disappointed with this machine.
I can't understand why the developers of the ReadyNas did not separate the frontview interface from the apache setup like a regular site. Would have made things so much easier.
Thanks
These were the errors i got:
Thanks
[Sun Feb 26 23:00:37 2012] [warn] module php5_module is already loaded, skipping
nas-eric:/etc/frontview/apache/addons# tail /var/log/frontview/error.log
[Sun Feb 26 22:48:01 2012] [error] Can't locate Frontview.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/ share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl . /frontview/ui/resource/html) at (eval 2) line 3.\n
[Sun Feb 26 22:48:01 2012] [error] Can't load Perl module Frontview for server localhost:80, exiting...
[Sun Feb 26 22:49:09 2012] [error] Can't locate Frontview.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/ share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl . /frontview/ui/resource/html) at (eval 2) line 3.\n
[Sun Feb 26 22:49:09 2012] [error] Can't load Perl module Frontview for server localhost:443, exiting...
[Sun Feb 26 22:53:33 2012] [error] Can't locate Frontview.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/ share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl . /frontview/ui/resource/html) at (eval 2) line 3.\n
[Sun Feb 26 22:53:33 2012] [error] Can't load Perl module Frontview for server localhost:443, exiting...
[Sun Feb 26 22:54:21 2012] [error] Can't locate Frontview.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/ share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl . /frontview/ui/resource/html) at (eval 2) line 3.\n
[Sun Feb 26 22:54:21 2012] [error] Can't load Perl module Frontview for server localhost:443, exiting...
[Sun Feb 26 23:00:37 2012] [error] Can't locate Frontview.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/ share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl . /frontview/ui/resource/html) at (eval 2) line 3.\n
[Sun Feb 26 23:00:37 2012] [error] Can't load Perl module Frontview for server localhost:443, exiting...
