devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys, For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it. 1. Backup all the .conf files in /etc/frontview/apache 2....
ericclaeren
Apr 27, 2012Aspirant
Thanks, have you updated your Nas to the latest version?
This is the result of the ps ax grep
When executing the apache-ssl command, I receiving the same error message
Don't get why this is happening after the update, everything was running just fine.
Thanks for your help!
3137 pts/0 S+ 0:00 grep apache
[Fri Apr 27 15:00:54 2012] [warn] module php5_module is already loaded, skipping
httpd not running, trying to start
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
