devbobo
Nov 29, 2009Aspirant
HOW TO: Hosting multiple websites
G'day Guys, For some time I've wanted to host multiple websites from a single ReadyNAS unit...I haven't had the time to investigate it. 1. Backup all the .conf files in /etc/frontview/apache 2....
leoj3n
Jul 15, 2012Aspirant
leoj3n wrote: Changing from /sites/ to /addons/ was fruitless. However I tried going to http://2011cc.otzo.com/index.php which gives the output:
Your server is running PHP version 5.2.0-8+etch16 but WordPress 3.4.1 requires at least 5.2.4.
However if you don't go directly to the index.php file you still get the permissions thing: http://2011cc.otzo.com/
An update: I finally thought to remove the .htaccess included with (correction: generated by, because I copied the WordPress files from my Desktop which was running a webserver and active WordPress install) WordPress and now the permission error goes away when you visit http://2011cc.otzo.com/
Going to http://2011cc.otzo.com/ does a directory-listing however, and doesn't automatically query index.php - that is what I will work on next.
Update: I had removed the following from the custom .vhost file during testing:
<Location />Adding it back causes index.php to be downloaded when visiting http://2011cc.otzo.com/ or http://2011cc.otzo.com/index.php ...
DirectoryIndex redirect.html index.html index.htm index.php
</Location>
