r32nj
Nov 11, 2019Tutor
How to modify audit settings on OS 6.10.2
I recently enabled the AUDIT function on my ReadyNAS. It is generating a huge # of entries (I turned everything on). I don't see any option on the AUDIT screen to turn it off or modify the original...
- Nov 11, 2019
r32nj wrote:
What you suggested was what I followed to turn ON auditing in the first place. Now how do I turn it off or modify the initial settings (as I am getting way to many entries with everything turned on)?
There are some settings for Audit in System->settings->services->audit that you can change.
Marc_V
Nov 11, 2019NETGEAR Employee Retired
You have to go to System>Logs and choose the Audit label on the left side. Auditing should be enabled first
Once enabled, the settings options should appear and you should be able to modify.
Please see http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf on page 247
HTH
Regards
- r32njNov 11, 2019Tutor
- StephenBNov 11, 2019Guru - Experienced User
This is what I needed - thank you! Might want to include this in the manual within the section about the audit function.
