r32nj
Nov 11, 2019Tutor
How to modify audit settings on OS 6.10.2
I recently enabled the AUDIT function on my ReadyNAS. It is generating a huge # of entries (I turned everything on). I don't see any option on the AUDIT screen to turn it off or modify the original...
- Nov 11, 2019
r32nj wrote:
What you suggested was what I followed to turn ON auditing in the first place. Now how do I turn it off or modify the initial settings (as I am getting way to many entries with everything turned on)?
There are some settings for Audit in System->settings->services->audit that you can change.
r32nj
Nov 11, 2019Tutor
Nov 11, 2019Guru - Experienced User
- r32njNov 11, 2019Tutor
This is what I needed - thank you! Might want to include this in the manual within the section about the audit function.
