kosata
Nov 21, 2016Aspirant
How to reinstall Photos II after uninstall (ReadyNAS 214)
Hi guys , uninstall Photos II and now it's not possible to find it in Apps section. I'm using 6.6 firmware and even after re-flash it, it's not shown in apps section. Some ideas how to reinstall it ?...
- Nov 21, 2016
Hi kosata,
Welcome to the community.
Please try to check the link below regarding app compatibility. I think there is a link for the Photos II in there.
NETGEAR app compatibility with ReadyNAS OS 6.6.0
JennC
Nov 25, 2016NETGEAR Employee Retired
Hi kosata,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
