decnal
Apr 01, 2016Aspirant
How to reset login password for ReadyNAS Surveillance
Hello, I installed the ReadyNAS Surveillance App several months ago to have a look-see and at that time changed the admin password to something more secure. I am now ready to connect a camera but...
- Apr 02, 2016
StephenB wrote:
I believe that Surveillance is supposed to use the NAS admin password. You might need L3 support's help to resolve this.
The default credentials are admin / password, but Surveillance uses a separate user database from the ReadyNAS.
decnal wrote:
Thanks for the help guys - I'll give customer support a try
Shouldn't even need a call to support.
- If you haven't changed the ReadyNAS admin user password (from the default password), you'll need to do that.
- Login to your volume's SMB share (default volume is data), like \\your_nas\data with the admin user.
- You may need to show hidden files, but should be able to go to .apps\surveillance\etc
- View the file called shadow, your password is there.
Lucie20
Feb 23, 2017Aspirant
Can you just run through logging into "your volumes SMB" I've had trouble with logging into the surveillance app.
- Nov 24, 2016Retired_Member
