bseos
Jul 04, 2013Aspirant
HowTo:Install Sabnzbd, Sickbeard & CouchPotato on ReadyNASO6
Required: Install Basic Development Packages & Python apt-get update apt-get -qy install apt-utils nano dialog whiptail apt-get -qy install build-essential ca-certificates libreadline-gplv2-...
wizzard
Jul 09, 2013Aspirant
Few errors, when it comes to coouchpotato:
etc/init.d/couchpotato start
might be ok
but
might be more problematic
nano ~/.couchpotato/settings.conf
catalog is none existing. catalog must be created first, no problem if an empty file with the info you posted is all that is supposed t be there.
[....] Starting couchpotato (via systemctl): couchpotato.serviceWarning: Unit file of created job changed on disk, 'systemctl --system daemon-reload' recommended.
. ok
might be ok
but
/etc/default/couchpotato not found using default settings.
