bseos
Jul 04, 2013Aspirant
HowTo:Install Sabnzbd, Sickbeard & CouchPotato on ReadyNASO6
Required: Install Basic Development Packages & Python apt-get update apt-get -qy install apt-utils nano dialog whiptail apt-get -qy install build-essential ca-certificates libreadline-gplv2-...
FilthyAmatuer
Jan 13, 2015Aspirant
Hi All,
First up thanks to bseos for the OP. This enabled me to get sickbeard and sabnzbd running on my readynas. I am still unfortunately having problems getting couchpotato to run. I am having the problem that F.L was having with couchpotato failing to start. F.L can use please elaborate a bit more on the steps you used to get couchpotato going. This would be much appreciated. Thanks.
