R0B3r7
Sep 20, 2016Tutor
Install USB TV Tuner to ReadyNAS firmware 6.5.2
I recently set up my ReadyNAS 312 with a USB tuner and Tvheadend to share the live TV signal across the network. It is all set up now and works great. The ReadyNAS did not have the required kerne...
ronitr
Oct 07, 2016Tutor
Hello.
I have updated firmware to 6.6.0 and the drivers don't work anymore. Can you make the driver for the new firmware? Thanks in advance
R0B3r7
Oct 11, 2016Tutor
ok, here are the current V4L-DVB drivers compiled to suit 6.6.0 x86_64
https://mega.nz/#!GdFGSJDJ!VTj2w7XdzuA8eSZ_rVjnyf2e9t_g9kGn-kl_RxrSbuQ
- ronitrOct 12, 2016Tutor
thanks for your reply
i have installed the new driver and the usb tuner works (avermedia A867)
but have a lot of errors
[ 22.351198] wsdd2[2644]: segfault at 0 ip 0000000000401ee0 sp 00007ffc2de24660 error 4 in wsdd2[400000+a000]
[ 23.015468] e1000e: eth0 NIC Link is Down
[ 23.585875] wsdd2[2747]: segfault at 0 ip 0000000000401ee0 sp 00007ffce6c1d4e0 error 4 in wsdd2[400000+a000]
[ 23.972987] wsdd2[2765]: segfault at 0 ip 0000000000401ee0 sp 00007fffd8f87560 error 4 in wsdd2[400000+a000]
[ 24.113366] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 24.113376] 8021q: adding VLAN 0 to HW filter on device eth0
[ 24.152823] wsdd2[2791]: segfault at 0 ip 0000000000401ee0 sp 00007ffe02c53190 error 4 in wsdd2[400000+a000]
[ 24.302918] i2c_mux: disagrees about version of symbol module_layout
[ 24.369985] wsdd2[2799]: segfault at 0 ip 0000000000401ee0 sp 00007ffd9bfb3c10 error 4 in wsdd2[400000+a000]
[ 24.423539] regmap_i2c: disagrees about version of symbol module_layout
[ 24.480768] tveeprom: disagrees about version of symbol module_layout
[ 24.543868] videodev: disagrees about version of symbol module_layout
[ 24.619434] videobuf_core: disagrees about version of symbol module_layout
[ 24.707041] videobuf_vmalloc: disagrees about version of symbol module_layout
[ 24.772864] v4l2_common: disagrees about version of symbol module_layout
[ 24.840213] tuner: disagrees about version of symbol module_layout
[ 24.909175] videobuf2_core: disagrees about version of symbol module_layout
[ 24.962771] videobuf2_memops: disagrees about version of symbol module_layout
[ 25.006740] videobuf2_vmalloc: disagrees about version of symbol module_layout
[ 25.021226] cxd2820r: disagrees about version of symbol module_layout
[ 25.060675] tda18271: disagrees about version of symbol module_layout
[ 25.070247] m88ds3103: disagrees about version of symbol module_layout
[ 25.078384] tda10071: disagrees about version of symbol module_layout
[ 25.147200] a8293: disagrees about version of symbol module_layout
[ 25.158382] si2157: disagrees about version of symbol module_layout
[ 25.215463] si2168: disagrees about version of symbol module_layout
[ 25.269592] em28xx: disagrees about version of symbol module_layout
[ 25.338987] em28xx_dvb: disagrees about version of symbol module_layout
[ 25.380974] tda10023: disagrees about version of symbol module_layout
[ 25.442975] tda10048: disagrees about version of symbol module_layout
[ 25.518042] tda827x: disagrees about version of symbol module_layout
[ 25.583581] dvb_usb_ttusb2: disagrees about version of symbol module_layout
[ 25.673209] dibx000_common: disagrees about version of symbol module_layout
[ 25.683805] dib3000mc: disagrees about version of symbol module_layout
[ 25.693358] dib8000: disagrees about version of symbol module_layout
[ 25.736641] dib7000m: disagrees about version of symbol module_layout
[ 25.793977] dib0090: disagrees about version of symbol module_layout
[ 25.858376] dib7000p: disagrees about version of symbol module_layout
[ 25.895547] dib0070: disagrees about version of symbol module_layout
[ 25.956720] dib9000: disagrees about version of symbol module_layout
[ 25.967681] dvb_usb_dib0700: disagrees about version of symbol module_layout
[ 26.014367] s5h1411: disagrees about version of symbol module_layout
[ 26.022377] xc5000: disagrees about version of symbol module_layout
[ 26.030386] au8522_common: disagrees about version of symbol module_layout
[ 26.038151] au8522_decoder: disagrees about version of symbol module_layout
[ 26.046978] au8522_dig: disagrees about version of symbol module_layout
[ 26.055644] au0828: disagrees about version of symbol module_layout
[ 26.065071] ts2020: disagrees about version of symbol module_layout
[ 26.102772] ds3000: disagrees about version of symbol module_layout
[ 26.157856] dvb_usb_dw2102: disagrees about version of symbol module_layout
[ 26.205536] ttpci_eeprom: disagrees about version of symbol module_layout
[ 26.213492] lnbp22: disagrees about version of symbol module_layout
[ 26.221626] stb0899: disagrees about version of symbol module_layout
[ 26.281766] stb6100: disagrees about version of symbol module_layout
[ 26.304074] dvb_usb_pctv452e: disagrees about version of symbol module_layout
[ 26.348265] stv090x: disagrees about version of symbol module_layout
[ 26.405416] as102_fe: disagrees about version of symbol module_layout
[ 26.472453] dvb_as102: disagrees about version of symbol module_layout
[ 26.500812] it913x: disagrees about version of symbol module_layout
[ 26.511712] sp2: disagrees about version of symbol module_layout
[ 26.520767] dvb_usb_dvbsky: disagrees about version of symbol module_layout- R0B3r7Oct 12, 2016Tutor
Looks like it is trying to use old modules. Did you delete all old ones before coping the new ones over?
These new v4l work fine with my RTL2832 tuners with no errors.
- ronitrOct 13, 2016Tutor
i have deleted all the old files and copied the new driver folder to kernel folder to 4.1.30.x86_64.1and the new firmware folder to /lib
