TeknoJnky
Jul 02, 2017Hero
installing handbrakecli 1.0.7
I am trying to get handbrakecli 1.0.7 installed. Installing via apt-get installs and older version, I beliieve 0.9.9 1.0.7 shows up as experimental @ https://packages.debian.org/search?keywor...
TeknoJnky
Jul 03, 2017Hero
well I am working on batch background converting hundreds of ripped dvd iso files to mp4 or mkv.
I am not sure if ffmpeg can read iso files, find the main title, then convert video to x264, copy all audio and subtitles into mp4 in as simple a process as handbrake.
And I already have everything setup for handbrake, I have found a work around for the 2 command line options above, but still I would like to have the most current version, not one that is a few years old.
dmacleo
Jul 03, 2017Guide
if I am right (and I cannot verify right now) the ffmpeg package itself CONTAINS these dependencies so if instalkled handbrake cli (which uses ffmpeg) would then pass check.
I've installed ffmpeg on many centos systems for cliipbucket video sites and pretty sure it contained all those. on deb based systems ffmpeg uses different name in repos, been so long cannot remember for sure (avconv maybe??) so would have to check
