johandenver
Dec 30, 2021Aspirant
Installing iDrive on ReadyNAS 102
Hi, I recently got a notification to upgrade to 6.10.6 on my ReadyNAS 102; and so I did. After some problems getting the device to even boot properly after the update it finally came up again and se...
johandenver
I also tried version 1.01.01 that I downloaded from Get Apps | ReadyNAS Applications but with the same error message.
- johandenverDec 30, 2021Aspirant
I started going through the logs in detail and found the below in the file install_debpkg
fv-app-install.c:674(error) fv-app-install (idrive): error code [100]: Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
libapache2-mod-php5 libmagic1 libmcrypt4 libonig2 libqdbm14 php5 php5-cli
php5-common php5-curl php5-json php5-mcrypt sudo
Suggested packages:
php-pear file libmcrypt-dev mcrypt php5-user-cache
Recommended packages:
php5-readline
The following NEW packages will be installed:
idrive libapache2-mod-php5 libmagic1 libmcrypt4 libonig2 libqdbm14 php5
php5-cli php5-common php5-curl php5-json php5-mcrypt sudo
0 upgraded, 13 newly installed, 0 to remove and 40 not upgraded.
Need to get 8,082 kB of archives.
After this operation, 32.2 MB of additional disk space will be used.
E: You don't have enough free space in /var/cache/apt/archives/.fv-app-install-utils.c:121(info) [idrive](0%) abort
Could this be the reason and if so, can I clear some space in /var/cache/apt/archives in some way?
- StephenBDec 30, 2021Guru - Experienced User
How full is the root (OS) partition?
It says 100% with about 35MB free. I'm currently trying to move /app/plexmediaserver to /Vol1 since I don't even have plexmediaserver installed. Are there any other files that are safe to remove?
Edit:
....and I just realized that /apps is its own partition so that won't help at all :-(
I did remove a core file earlier but that was all I could find that would clear som space so I'd be very happy for some tips regarding what to safely remove :-)
