johandenver
Dec 30, 2021Aspirant
Installing iDrive on ReadyNAS 102
Hi, I recently got a notification to upgrade to 6.10.6 on my ReadyNAS 102; and so I did. After some problems getting the device to even boot properly after the update it finally came up again and se...
johandenver
I also tried version 1.01.01 that I downloaded from Get Apps | ReadyNAS Applications but with the same error message.
johandenver
I started going through the logs in detail and found the below in the file install_debpkg
fv-app-install.c:674(error) fv-app-install (idrive): error code [100]: Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
libapache2-mod-php5 libmagic1 libmcrypt4 libonig2 libqdbm14 php5 php5-cli
php5-common php5-curl php5-json php5-mcrypt sudo
Suggested packages:
php-pear file libmcrypt-dev mcrypt php5-user-cache
Recommended packages:
php5-readline
The following NEW packages will be installed:
idrive libapache2-mod-php5 libmagic1 libmcrypt4 libonig2 libqdbm14 php5
php5-cli php5-common php5-curl php5-json php5-mcrypt sudo
0 upgraded, 13 newly installed, 0 to remove and 40 not upgraded.
Need to get 8,082 kB of archives.
After this operation, 32.2 MB of additional disk space will be used.
E: You don't have enough free space in /var/cache/apt/archives/.
fv-app-install-utils.c:121(info) [idrive](0%) abort
Could this be the reason and if so, can I clear some space in /var/cache/apt/archives in some way?
- StephenBDec 30, 2021Guru - Experienced User
How full is the root (OS) partition?
- johandenverDec 30, 2021Aspirant
It says 100% with about 35MB free. I'm currently trying to move /app/plexmediaserver to /Vol1 since I don't even have plexmediaserver installed. Are there any other files that are safe to remove?
Edit:
....and I just realized that /apps is its own partition so that won't help at all :-(
I did remove a core file earlier but that was all I could find that would clear som space so I'd be very happy for some tips regarding what to safely remove :-)
I found a huge logfile from Squeezebox (which I think I tried using long ago) that seemed to clear up a lot of space. I now have 67% free on /
However, now I get this error instead (I've tried adding 8.8.8.8 as a secondary DNS)
fv-app-install-utils.c:106(info) Downloading [idrive](12%) Retrieving file 2 of 13
fv-app-install.c:674(error) fv-app-install (/tmp/idrive_armel.deb): error code [100]: Reading package lists...
Suggested packages:
php5-readline
Need to get 5,899 kB/8,101 kB of archives.
After this operation, 32.3 MB of additional disk space will be used.
Get:1 /tmp/idrive_armel.deb idrive armel 1.01.02 [2,201 kB]
Err:2 http://security.debian.org jessie/updates/main armel libmagic1 armel 1:5.22+15-2+deb8u7
Could not resolve 'security.debian.org'
Err:3 http://mirrors.kernel.org/debian jessie/main armel libqdbm14 armel 1.8.78-5+b1
Could not resolve 'mirrors.kernel.org'
Err:4 http://security.debian.org jessie/updates/main armel libonig2 armel 5.9.5-3.2+deb8u4
Err:5 http://mirrors.kernel.org/debian jessie/main armel php5-json armel 1.3.6-1
Err:6 http://security.debian.org jessie/updates/main armel php5-common armel 5.6.40+dfsg-0+deb8u12
Err:7 http://mirrors.kernel.org/debian jessie/main armel libmcrypt4 armel 2.5.8-3.3
Err:8 http://security.debian.org jessie/updates/main armel php5-cli armel 5.6.40+dfsg-0+deb8u12
Err:9 http://security.debian.org jessie/updates/main armel libapache2-mod-php5 armel 5.6.40+dfsg-0+deb8u12
Ign:10 http://security.debian.org jessie/updates/main armhf php5 all 5.6.40+dfsg-0+deb8u12
Err:11 http://security.debian.org jessie/updates/main armel php5-curl armel 5.6.40+dfsg-0+deb8u12
Err:12 http://security.debian.org jessie/updates/main armel php5-mcrypt armel 5.6.40+dfsg-0+deb8u12
Err:13 http://security.debian.org jessie/updates/main armel sudo armel 1.8.10p3-1+deb8u7
Err:10 http://security.debian.org jessie/updates/main armhf php5 all 5.6.40+dfsg-0+deb8u12
E: Failed to fetch http://security.debian.org/pool/updates/main/f/file/libmagic1_5.22+15-2+deb8u7_armel.deb Could not resolve 'security.debian.org'E: Failed to fetch http://security.debian.org/pool/updates/main/libo/libonig/libonig2_5.9.5-3.2+deb8u4_armel.deb Could not resolve 'security.debian.org'
E: Failed to fetch http://mirrors.kernel.org/debian/pool/main/q/qdbm/libqdbm14_1.8.78-5+b1_armel.deb Could not resolve 'mirrors.kernel.org'
E: Failed to fetch http://security.debian.org/pool/updates/main/p/php5/php5-common_5.6.40+dfsg-0+deb8u12_armel.deb Could not resolve 'security.debian.org'
E: Failed to fetch http://mirrors.kernel.org/debian/pool/main/p/php-json/php5-json_1.3.6-1_armel.deb Could not resolve 'mirrors.kernel.org'
E: Failed to fetch http://security.debian.org/pool/updates/main/p/php5/php5-cli_5.6.40+dfsg-0+deb8u12_armel.deb Could not resolve 'security.debian.org'
E: Failed to fetch http://security.debian.org/pool/updates/main/p/php5/libapache2-mod-php5_5.6.40+dfsg-0+deb8u12_armel.deb Could not resolve 'security.debian.org'
E: Failed to fetch http://mirrors.kernel.org/debian/pool/main/libm/libmcrypt/libmcrypt4_2.5.8-3.3_armel.deb Could not resolve 'mirrors.kernel.org'
E: Failed to fetch http://security.debian.org/pool/updates/main/p/php5/php5_5.6.40+dfsg-0+deb8u12_all.deb Could not resolve 'security.debian.org'
E: Failed to fetch http://security.debian.org/pool/updates/main/p/php5/php5-curl_5.6.40+dfsg-0+deb8u12_armel.deb Could not resolve 'security.debian.org'
E: Failed to fetch http://security.debian.org/pool/updates/main/p/php5/php5-mcryp
