MaartenProvo
Feb 10, 2016Aspirant
Installing SickRage
Hello I'm trying to install SickRage using this guide: https://sickrage.tv/forums/forum/help-support/general-support/6013-sickrage-ubuntu-install-guide . It appears to be working, but stops as so...
Bogus
Mar 05, 2016Tutor
No, I wish it was that simple. I checked that and made sure the torrent wasn't seeding anymore. Even manual post processing gave the same error. It can copy but not move.
Reaves
Mar 07, 2016Aspirant
Thanks for making the package. I'll try it out.
For transmission issues I've had that before. Are both sickrage and transmission installed on the data volume?
You could try changing the folder permissions using something like FILEZILLA.
