MaartenProvo
Feb 10, 2016Aspirant
Installing SickRage
Hello I'm trying to install SickRage using this guide: https://sickrage.tv/forums/forum/help-support/general-support/6013-sickrage-ubuntu-install-guide . It appears to be working, but stops as so...
x219c
Mar 13, 2016Luminary
I've always had transmission download to a different folder inside my media share. Not the transmission share. Then sickbeard watches there. Once it finishes downloading, it can move the files around because they're not going across shares.
- BogusMar 18, 2016Tutor
Yes, that works indeed. Thanks!
- MhynloMar 18, 2016Luminary
This package is now available on the app site:
- x219cMar 28, 2016Luminary
Mhynlo,
I am getting an error when trying to restart sickrage. It is saying: "Empty resource error: bad MNL call." This is only happening after shutting down sickrage, then attempting to restart from frontview. I had previously thought it had to do with a hard shutdown, but after getting the app reinstalled... It worked until I shut down, now I'm getting that error.
Do you know what it might be?
Up until this point everything's been working great, and I thank you for putting this together!
