MaartenProvo
Feb 10, 2016Aspirant
Installing SickRage
Hello I'm trying to install SickRage using this guide: https://sickrage.tv/forums/forum/help-support/general-support/6013-sickrage-ubuntu-install-guide . It appears to be working, but stops as so...
x219c
Mar 13, 2016Luminary
I've always had transmission download to a different folder inside my media share. Not the transmission share. Then sickbeard watches there. Once it finishes downloading, it can move the files around because they're not going across shares.
Bogus
Mar 18, 2016Tutor
Yes, that works indeed. Thanks!
- MhynloMar 18, 2016Luminary
This package is now available on the app site:
- x219cMar 28, 2016Luminary
Mhynlo,
I am getting an error when trying to restart sickrage. It is saying: "Empty resource error: bad MNL call." This is only happening after shutting down sickrage, then attempting to restart from frontview. I had previously thought it had to do with a hard shutdown, but after getting the app reinstalled... It worked until I shut down, now I'm getting that error.
Do you know what it might be?
Up until this point everything's been working great, and I thank you for putting this together!
- MhynloMar 29, 2016Luminary
I have seen this issue on by box.
I need to spend sometime to see where the root of the issue is appening.
I was seeing when I restart (or update) the SickRage service in the UI; the service does not inform systemd that the service restarts, so I need to see where the disconnect is.
Are you not able to turn on the app at this time?
