MaartenProvo
Feb 10, 2016Aspirant
Installing SickRage
Hello I'm trying to install SickRage using this guide: https://sickrage.tv/forums/forum/help-support/general-support/6013-sickrage-ubuntu-install-guide . It appears to be working, but stops as so...
Bogus
Mar 18, 2016Tutor
Yes, that works indeed. Thanks!
Mhynlo
Mar 19, 2016Luminary
This package is now available on the app site:
- x219cMar 29, 2016Luminary
Mhynlo,
I am getting an error when trying to restart sickrage. It is saying: "Empty resource error: bad MNL call." This is only happening after shutting down sickrage, then attempting to restart from frontview. I had previously thought it had to do with a hard shutdown, but after getting the app reinstalled... It worked until I shut down, now I'm getting that error.
Do you know what it might be?
Up until this point everything's been working great, and I thank you for putting this together!
- MhynloMar 29, 2016Luminary
I have seen this issue on by box.
I need to spend sometime to see where the root of the issue is appening.
I was seeing when I restart (or update) the SickRage service in the UI; the service does not inform systemd that the service restarts, so I need to see where the disconnect is.
Are you not able to turn on the app at this time?
Yeah, I'm not able to turn it on. I can SSH in, but it wouldn't let me start the service (though, maybe I have the wrong name)
