Yoda3647
Aug 02, 2021Aspirant
Instruction on VPN for NAS
Yes can someone please give me step by step intruction on Installing and using a VPN on my NAS???
Yoda3647
Aug 03, 2021Aspirant
how different is a Synology NAS from a ready nas?? on unlimited vpn webcite it has this:
https://www.vpnunlimited.com/help/manuals/synology-openvpn-setup
My Router is not listed aa a supported router. I have a Netgear AC1900 Model C6900. I purchased this Router becuase it was Garanteed to work with Xfinity, so even if I could put DD-wrk or Tomato on it would it still be garanteed to work with my internet pervider
Aug 04, 2021Guru - Experienced User
I've never owned a Synology. But my response on VPN Unlimited needing Debian 10 came from here: https://www.vpnunlimited.com/help/manuals/linux And I know OS-6 uses Debian Jessie (which is Debian 8).
Not sure you could install it on the C6900. It'd probably be better to configure the C6900 as a pass-through modem (which is definitely possible), and use a second router behind it as a VPN router. The assumption here is that you'd want privacy on all your device connections, just not the NAS.
If the desire for privacy is specifically related to transmission, then you just run that on a PC with the VPN Unlimited client installed.
- Yoda3647Aug 04, 2021Aspirant
I have my VPNunlimited on my PC but every now and then depending on wedcite I turn it off, so yes this would be for the NAS if possible plus if the NAS is doing it's thing it will not slow my PC down if I need to use it at the same time. Hey I gott a Idea would there be a way to use a 2nd Router on my Network and have it be a VPN router so whatever is hooked to it will be Hidden and everthing else is on there own?? My VPN acount can do up to 5 Devices so that covers My wife and I, so if a VPN router is easer then configuring the NAS with VPN then use a VPN Router just for the NAS????
- SandsharkAug 04, 2021Sensei
You should be able to install OpenVPN on your NAS using SSH then use the configuration information for it provided by VPNunlimited.
Since your 316 had two Ethernet ports, you could attach one directly to your home network and the other to a secondary VPN router if it doesn't pass through both VPN and non-VPN traffic. This article may help you in setting up that secondary router: Setup-two-routers-with-dedicated-vpn-router .
But telling the NAS and any other device that's connected to this when to use the VPN and when to use the open connection is yet another issue.
Okay how would I install OpenVPN on my NAS? never used SSH before I have mounted my NAS as drive "T" on my PC to install a Bundle file for Plex. Any and all help appreciated. If you could give me a Step by Step for installing OpenVPN or if one is already written a link to it. and thanks for all the help
- Yoda3647Aug 10, 2021Aspirant
- StephenBAug 10, 2021Guru - Experienced User
I've never installed the OpenVPN client (which is what you would need) on my own ReadyNAS, so I'm not in a position to give you step-by-step instructions.
As Sandshark mentioned, it's not enough to install the client. You also need to set it up so that only the desired internet connections use it. Otherwise you will lose local access to the NAS. Again, not something I've needed to do, and folks here who have tried to route different applications through different networks have struggled getting that to work.
Okay, I will do some reasearch if I find the answer will post here on tis thread
- Yoda3647Aug 20, 2021Aspirant
How about this...I turn off the Router function on my Nighthawk C6900 Modem/Router combo and purchase NETGEAR - Nighthawk RAX45 AX4300 Wi-Fi 6 Router which has built in VPN support and hook that to the modem to use as my Router then I would have VPN for my NAS and everything else correct?? or do I still need to instal a VPN client on the NAS still ????
- StephenBAug 20, 2021Guru - Experienced User
Look at chapter 10 here. https://www.downloads.netgear.com/files/GDC/RAX45/RAX45_UM_EN.pdf
Nighthawks include an OpenVPN server that gives you secure access to your home network when you are away from home. As we've tried to say before, that is very different from using a VPN to prevent your ISP from seeing your internet traffic. The OpenVPN feature in the Nighthawk can't be used to connect to your vpnunlimited service.
There was a list of routers you could use here: https://www.vpnunlimited.com/help/manuals/vpn-routers I haven't used any of them, so I have no recommendation on how they'd compare with your current router.
