JeffAtK2
Jan 30, 2020Guide
XS728T FIRMWARE UPDATE INSTRUCTIONS
Hi,
The firmware download page says refer to the user manual for firmware update instructions. The user manual ( User Manual ) only acknowledges updates may exist and does not explain how to go about applying them.
Can someone provide me with a direct link to the firmware update instructions? I'm trying to update to 6.5.1.42 from 6.5.1.36.
Thanks,
Jeff
Usually, the Update Procedures are part of the Release Notes - why ever, on the current firmware it appears to be missing.
Check the previous firmware https://kb.netgear.com/000060622/XS728T-XS748T-Firmware-Version-6-5-1-36 for the Update Procedures, use the similar process with the current version number.
Check the previous firmware https://kb.netgear.com/000060622/XS728T-XS748T-Firmware-Version-6-5-1-36 for the Update Procedures, use the similar process with the current version number.- JeffAtK2Guide
Thank you!! That's exactly what I was looking for.
Jeff
