GJSchaller
Sep 18, 2018Guide
Issue installing sudo using apt-get
I am attempting to install sudo on my ReadyNAS to be able to run some stuff from the command line. When I attempt to do so using apt-get, I get an error - full output is below (Spaces are added for ease of reading):
Welcome to ReadyNASOS 6.9.4 Last login: Tue Sep 18 16:28:19 2018 from ool-2f160162.static.optonline.net root@GeoffNAS:~# apt-get install sudo Reading package lists... Done Building dependency tree Reading state information... Done You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: mariadb-server : Depends: mariadb-server-10.0 (>= 10.0.36-0+deb8u1) but 10.0.35-0+deb8u1 is to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). root@GeoffNAS:~# apt-get -f install Reading package lists... Done Building dependency tree Reading state information... Done Correcting dependencies... Done The following package was automatically installed and is no longer required: libssh2-1 Use 'apt autoremove' to remove it. The following additional packages will be installed: mariadb-server-10.0 Suggested packages: mailx mariadb-test tinyca Recommended packages: libhtml-template-perl The following packages will be upgraded: mariadb-server-10.0 1 upgraded, 0 newly installed, 0 to remove and 12 not upgraded. 4 not fully installed or removed. Need to get 0 B/3,435 kB of archives. After this operation, 11.3 kB disk space will be freed. Do you want to continue? [Y/n] Y debconf: delaying package configuration, since apt-utils is not installed (Reading database ... 37099 files and directories currently installed.) Preparing to unpack .../mariadb-server-10.0_10.0.36-0+deb8u1_armel.deb ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline 2540 There is a MySQL server running, but we failed in our attempts to stop it. Stop it yourself and try again! dpkg: warning: subprocess old pre-removal script returned error exit status 1 dpkg: trying script from the new package instead ... debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline 2540 There is a MySQL server running, but we failed in our attempts to stop it. Stop it yourself and try again! dpkg: error processing archive /var/cache/apt/archives/mariadb-server-10.0_10.0.36-0+deb8u1_armel.deb (--unpack): subprocess new pre-removal script returned error exit status 1 debconf: unable to initialize frontend: Dialog debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76.) debconf: falling back to frontend: Readline insserv: warning: current start runlevel(s) (empty) of script `mysql' overrides LSB defaults (2 3 4 5). insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script `mysql' overrides LSB defaults (0 1 6). Errors were encountered while processing: /var/cache/apt/archives/mariadb-server-10.0_10.0.36-0+deb8u1_armel.deb E: Sub-process /usr/bin/dpkg returned an error code (1) root@GeoffNAS:~#
- kohdeeNETGEAR Expert
You are failing to install mariadb... you need to remove that since it is not installing properly and then try to install sudo.
[edit] it actually says you have mysql running and you need to stop it before you can install mariadb.
- SandsharkSensei
Since you log in via SSH as ROOT, you don't need sudo. Just run the command.
The function I was needing to run was giving a message it needed to be run specifically as Admin, not Root, but I realized I was able to just SSH in as Admin and do it that way instead.
