sander11
Jan 01, 2014Aspirant
Light weight web-based monitoring tool
Can anyone suggest a good light weight monitoring solution for keeping an eye on the load and temperature of the readynas. I'm trying to build a small home lab using virtualbox and I just want somethi...
sorenfriis
Jan 02, 2014Aspirant
A lot of of information is being exposed over SNMP, if you enable it (I don't remember if it requires an addon to enable).
The ReadyNAS SNMP MIB is available for download at the readynas website.
So you might be able to find a good SNMP tool which can monitor the OID's you need.
