super_poussin
Jan 18, 2009Virtuoso
LLINK 3.0
LLINK
Installation Notes: none
Screenshots:
Old Versions: initial release
Credits and sources :
LLink
- Description: Media Streamer for Syabas Platform
- Requirements: RAIDiator 4.2.3+
- Platform: PRO/NVX
- Current Version:3.0
Llink 2.2.2 (11/04/10)
Llink (01/18/09)- based on llink 2.2.2
- correct skin location problem
- you can know modify the llink.conf without ssh access (llink.conf is under webroot/llink/ share)
- Added UDF2.50 support to dvdread for BD-5 ISO images. (HD-DVD as well, in theory)
- Added support to UDF list files (instead of just domain,title DVD lookup)
- Jukebox page 2 and up incorrectly handled Separator for files.
- libdvdnav fails to open paths with /VIDEO_TS/. Reverted function from libdvdread.
- Changed pass=0 to list and cache only. Pass=1+ simply replays cache. No need for lastline etc.
- Fix history code so parent sets from page and focus correctly.
- Fix focus setting
- Add user-set sort-types in conf
- Add sort-by cgi key, and MACROS to control sorting.
- Fixed SSDP to also work against xbox360 and Playstation3 (query only, more work needed for actual use)
- Added option to automatically expand RAR files when listing.
- Added option to automatically expand ISO files when listing.
- Added option to allow sending of index.html file if present in directory
- New MACROs for current page, tvid-tvid and total pages, total files.
- Minor changes in extra-info, directory.ext was terminated at .ext
LLink
1 Reply
- super_poussinVirtuosoupdated as requested
