Solo21's avatar
Solo21
Tutor
Jun 27, 2020
Netgear xr500 netduma 3.0
Hi I recently downloaded netduma 3.0 to my xr500 as part of the beta participants. i l updated my router and done a factory reset on thinking that ill reset my settings back to default for the 3.0 and so while it was updating again i lost my internet connection and cant log back in the router through myrouterlogin.com and wont connect to the internet. I need someone to help me log back into ny router and get internet back
  • For 3.0 related queries could you post in the beta forum please?
    Once there can you access using the LAN IP via a wired PC and see if it prompts you to do the setup wizard please?
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      • Solo21's avatar
        Solo21
        Tutor
        Ahaa Forgot that I had to use ethernet for the setup. Thank you so much, all is well now. I can finally enjoy destroying newbs on apex legends again.😊
