ncameron
Jun 07, 2016Aspirant
LMS NT & M4A Files
I have a new ReadyNAS 314 running OS 6.2. I installed the proferred LMS NT App and am currently running it with a software SqueezePlay player, as my hardware players are elsewhere at present. It wor...
- Jul 20, 2016
That bloody well worked!
I can't thank you enough. My listening life is transformed.
Shouldn't this be built into the general relased code?
Neil
Jun 07, 2016Guru - Experienced User
Are these really AAC, or are they apple lossless?
If you change the extension to mp4, does that help?
ncameron
Thay are actuallty Apple Lossless M4A files.
I tried changing the file extention to MP4, but that did not help.
- StephenBJun 07, 2016Guru - Experienced User
So that must be the issue. Do you have a FLAC file you can try as a test?
I don't use LMS or squeezebox, but I have heard that some devices don't have native ALAC support (but do have FLAC).
- ncameronJun 07, 2016Aspirant
When you say "that must be the issue" - does that mean, LMS NT, SqueezePlay or the absence of LAME?
The issue being the system doesn't support ALAC - not sure which component(s). Initially you said AAC m4a, which would have pointed me towards a file extension problem or perhaps file permissions (since AAC is the standard audio compression in mp4).
