ncameron
Jun 07, 2016Aspirant
LMS NT & M4A Files
I have a new ReadyNAS 314 running OS 6.2. I installed the proferred LMS NT App and am currently running it with a software SqueezePlay player, as my hardware players are elsewhere at present. It wor...
- Jul 20, 2016
That bloody well worked!
I can't thank you enough. My listening life is transformed.
Shouldn't this be built into the general relased code?
Neil
ncameron
Jun 10, 2016Aspirant
If such support could be added that would be awsome - please let me know...
NAStools
Jun 10, 2016Luminary
ncameron wrote:If such support could be added that would be awsome - please let me know...
I'll work on an updated package and send it over this weekend.
ncameron wrote:Just a thought; if I enable the ReadyNAS iTunes Server, will that not then play ALAC/M4A files?
StephenB wrote:It might - I'm not sure. You won't be able to use squeezeplay to play them.
Yep, the iTunes server should play those files, but only to iTunes.
- NAStoolsJun 17, 2016Luminary
Sorry, I got a little busy last weekend and this week. Can you try out this package and let me know how it works?
armel (just in case) - https://www.dropbox.com/s/idc07poxln9t20l/nastools-logitechmediaserver_7.9.0~20160617.858e1e0-nt1_armel.deb
- ncameronJun 18, 2016Aspirant
Thanks so much. I'm in the wrong continent now for another few weeks; I'll try it out as soon as I get back, and will report back...
- ncameronJul 19, 2016Aspirant
Hi there. I am finally back in the US, and ready to give this a try. For the avoidance of doubt, and so I do not screw up my system: how do I know which version of these to use, and (more importantly) what do I do with it?!
- NAStoolsJul 19, 2016Luminary
armel for ReadyNAS 102/104/202/204/212/214/2120. amd64 for everything else. The web interface will tell you if you use the wrong one. :robothappy:
Use the Upload button in the Apps tab to get it on your system.
