ncameron
Jun 07, 2016Aspirant
LMS NT & M4A Files
I have a new ReadyNAS 314 running OS 6.2. I installed the proferred LMS NT App and am currently running it with a software SqueezePlay player, as my hardware players are elsewhere at present. It wor...
- Jul 20, 2016
That bloody well worked!
I can't thank you enough. My listening life is transformed.
Shouldn't this be built into the general relased code?
Neil
NAStools
Jun 10, 2016Luminary
ncameron wrote:If such support could be added that would be awsome - please let me know...
I'll work on an updated package and send it over this weekend.
ncameron wrote:Just a thought; if I enable the ReadyNAS iTunes Server, will that not then play ALAC/M4A files?
StephenB wrote:It might - I'm not sure. You won't be able to use squeezeplay to play them.
Yep, the iTunes server should play those files, but only to iTunes.
NAStools
Jun 17, 2016Luminary
Sorry, I got a little busy last weekend and this week. Can you try out this package and let me know how it works?
armel (just in case) - https://www.dropbox.com/s/idc07poxln9t20l/nastools-logitechmediaserver_7.9.0~20160617.858e1e0-nt1_armel.deb
- ncameronJun 18, 2016Aspirant
Thanks so much. I'm in the wrong continent now for another few weeks; I'll try it out as soon as I get back, and will report back...
- ncameronJul 19, 2016Aspirant
Hi there. I am finally back in the US, and ready to give this a try. For the avoidance of doubt, and so I do not screw up my system: how do I know which version of these to use, and (more importantly) what do I do with it?!
- NAStoolsJul 19, 2016Luminary
armel for ReadyNAS 102/104/202/204/212/214/2120. amd64 for everything else. The web interface will tell you if you use the wrong one. :robothappy:
Use the Upload button in the Apps tab to get it on your system.
- ncameronJul 20, 2016Aspirant
Neil
