fishgoh0nk's avatar
Sep 15, 2012
Minecraft server addon for PRO - almost done, UI not working
Hello All,
I was successful in creating a minecraft addon that had working start, stop and running scripts as well as an install bin. The problem is the UI doesn't seem to successfully start/stop even though i can run the scripts to successfully launch the java in console. I compared my handler file with other addons (transmission) for one as well as the javascript and xml file. I can't seem to figure out what's wrong - even when I enable the check box and click save, the /etc/default/services file is not being updated to enabled. what could be wrong?
I've already checked my permissions, made sure those are alright, then went through and did a compare on the handlers; didn't see a problem. is there an exit code i should be omitting or returning for on start.sh?
  • If you're working on the x86 platform: What version of Java do you use? Also it'd be interesting to see your install.sh. If you want to, I can have a look at your add-on if you send me a link for downloading.
    -Stefan
  • Do you have a wurking Minecraft server Addon for the x86 system?
ProSupport for Business
