Witzker
Jul 08, 2016Aspirant
MySql for RND 2000 V1
Hi
Where can I download
THX FOR LINK
regards
It's already installed actually. This old post might help: http://readynas.sphardy.com/2011/06/setting-up-website-with-php-mysql_6972.html
- WitzkerAspirant
THX
I tried to download
PppMyAdmin like discribed below
Once MySQL is enabled, there is of course a requirement to create and manage the MySQL databases. If you have enabled root SSH access to your NAS, then you can of course manage MySQL from the command line. For those less adept with commandline access, there is an application called phpMyAdmin (x86 version, sparc version) that can be installed to provide a web based graphical front end to managing MySQL.
Sparc version
But I get a page saying Access Denied?
What have I done wrong?
Where ca I get the richt addons?
Same at here
Installing PHP
PHP support can be enabled by installing one of PHP addons available from the ReadyNAS Community Addons forum. Personally I would recommend the "WhoCares?" PHP 5.2 addons - x86 version, sparc version - as these tend to be compatible with all other addons, have worked well for me over the years and come with the modules required for PHP access to MySQL databases. Other versions of PHP addons may provide additional features that may be required, so check them out.- StephenBGuru - Experienced User
The pages are old, the links go back into the original ReadyNAS forum which is now offline.
Can you see this one? https://community.netgear.com/t5/Community-Add-ons-archive/PHPMyAdmin-v2-5/m-p/652229#p114904 If not, I can copy/paste it here if you like. It's a super_poussin add-on.
If you want the ones from WhoCares_, you can find them here: https://rnxtras.com/readynas-os4-sparc
