sgallou
Nov 16, 2012Follower
mysql-server installation on Duo
I'm newbie on the ReadyNas Duo (and generally on Linux), and I have trouble installing mysql-server (I need it because I want to try domogik on the Nas). First I think that mysql-server was already...
mfe_
Mar 03, 2013Tutor
Try to execute:
If this dont work, look into the config file /etc/mysql/my.cnf and enable logging.
Then view the errormessage with tail yourPathToLogFile.
I had an issue, that the user admin wasn't the owner of the mysql datadir folder.
Good luck.
/usr/sbin/mysqld -- \
--basedir=/usr --pid-file=/var/run/mysqld/mysqld.pid --skip-locking --socket=/var/run/mysqld/mysqld.sock
Good luck.
